[re: 2007 Camry-LE, 4-cyl, auto, US built]
Hello:
I need to replace the "release cables" for the both the Trunk-lid and Fuel-door.
What is the reccommended procedure to replace these "release-cables"?
Any Tips & Tricks?
Any Shortcuts ... i.e. like pulling NEW cables with the old-cables during removal ?
thnx for you knowledgable assistance and advice ...
Jeff K.
note :
I did locate the below post for a 2005 Camry ...
is the 2007 Camry procedure any different?
http://www.toyotafans.net/index.php?...39&#entry48539
FYI ... additional info :
The release mechanisms for both the fuel-door and trunk-lip are fully functional.
It is only that the release-cables are binding somewhere between the ends.
Unfortunately due to some corrosion inside the release cables ( for both Fuel door and Truck-Lid), the release-cables are binding ( excess friction, chafing ) and not returning to the rest position after using the manual release levers ( next to drivers seat).
The corrosion (I believe) is from minor flooding in 2008 during hurricane IKE, when flood waters reached just into floorboard ( carpet was soaked ).
On at least 5 occasions, I have "fixed" the problem... temporarily ....
i.e. I made inside-cables "slide freely" and injected both WD-40 and silicone-spray lubrucants into both ends of the release cables to coat metal parts, Hoping that this would prevent release cables from further binding. ...
During each "repair-fix" , the release-cables are well lubricated and slide freely. After re-assembly, the fuel-door and trunk-lid open normally with the manual release lever (testing many times).
Unfortunately, after approximately 1+ week of NON-USE, the cables again bind-up and do-not return to the rest-position and again requiring disassembly at the manual lever and manually freeing the stuck-cable and re-lubrication.
