Upgrading High Beam / DRL bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2010, 02:24 PM   #1 (permalink)
View vipermaniac's Photo Gallery
Gen6 Upgrading High Beam / DRL bulbs
I'm just wondering how it works, but I'm interested in purchasing 9005 PIAA bulbs for my 2010 Camry SE to run as mainly DRL. Will this work the same as the stock OEM ones? I don't need them to work at night, as I just simply don't like the yellow stock DRL.
I just want to confirm that in DRL mode, it will be dim white, whereas it will be bright white in High Beam mode.
The item is
http://www.amazon.com/19615-HB3-9005-Style-Xtreme-120-Watt/dp/B00067BW6S http://www.amazon.com/19615-HB3-9005-Style-Xtreme-120-Watt/dp/B00067BW6S
Thanks!
vipermaniac is offline   Reply With Quote
Old 07-16-2010, 02:39 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
The item is
Thanks!
They will not be white in DRL mode.........
Old 07-16-2010, 02:48 PM   #3 (permalink)
if not white, what color would it be? Or it won't be on at all?
Old 07-16-2010, 03:00 PM   #4 (permalink)
'07 XLE
Gen6
Whiter than OEM, but still yellowish at reduced voltage.
Old 07-16-2010, 03:11 PM   #5 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
You could probably get some fairly white DRL look, as long as you're OK with bright blue looking HIghbeams or something.
MJZ is offline   Reply With Quote
Old 07-16-2010, 06:22 PM   #6 (permalink)
Hello, Good Morning
ItsMeJon's Avatar
View ItsMeJon's Photo Gallery
If you don't use your high beams and want white drls get LEDs Ive bin thinking about doing it.
ItsMeJon is offline   Reply With Quote
Old 07-16-2010, 09:15 PM   #7 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
get 4300k-5k led bulbs n problem solved.
WrongFitmentCrew#628
