2002 Camry engine check light on and off
Hi, I have a question.
I have a used 2002 Toyota Camry LE with 128 K mi. I recently had it checked comprehensively at meineke and was told that everything was perfect. Today while on the road I suddenly felt a loss of acceleration and the engine check light came on, I could drive with minimum power only (the same that you have with the gear engaged in drive mode). I stopped after a mile and restarted, the light remained on but I was able to accelerate normally. I parked the car for 2 hours and then when I started it again, there was neither any check light nor any acceleration problem. Should I be concerned?
thanks
