Originally Posted by Luna2
Is your car an I4 or V6? Japan or US made? The Japan version uses more pins than the us version of the I4....
Check out www."CamryStuff.com" (Direct links to manuals are not permitted, Forum Rule 15. Copy, paste & remove quotes)
Lots of good info for your Gen 5.
I'm not sure...not much of a car guy.
The only sensor on the TB was held on with rivets. I put everything back together, then went under the dash by the gas pedal. I disconnected the sensor down there and reconnected it....
Viola! It works perfectly.
When it craps out again, which I sure won't be long, I'll pick up the accelerator pedal position sensor and replace.
