2002 camry won't start after throttle body cleaning. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2010, 07:22 PM   #1 (permalink)
View tkkidd's Photo Gallery
Gen5 2002 camry won't start after throttle body cleaning.
Ahh crap .
I have 2002 4cyl toyota camry SE model.
I tried clean throttle body after readint the posts here.
I wanted to do a wrtei up afterwards ( one for gen 5 4cly.. ) so i took many pictures along the way.
I just connected back up and it won't start...
Help!!
symtoms before the cleaning..
it was ideling at low rpm and stall on stop lights.
what i did cleaned the throttle body.
tkkidd is offline   Reply With Quote
Old 07-23-2010, 07:36 PM   #2 (permalink)
LoudCamry's Avatar
Gameroom cash: $229927
View LoudCamry's Photo Gallery
remove the battery and reconnect it.
also did you reconnect all the hose that you remove?
LoudCamry is offline   Reply With Quote
The Following User Says Thank You to LoudCamry For This Useful Post:
tkkidd (07-23-2010)
Old 07-23-2010, 07:38 PM   #3 (permalink)
battery was disconnected for 30 min because I also cleaned the battery terminal... i double check the hose connection... i think it's all back at where it shoue be.,..
Old 07-23-2010, 08:28 PM   #4 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
you could take a pic of the engine bay where you d/c the hoses and anythin you think could cause the car to not start up
Dave-o is offline   Reply With Quote
The Following User Says Thank You to Dave-o For This Useful Post:
tkkidd (07-23-2010)
Old 07-23-2010, 08:30 PM   #5 (permalink)
Problem solved.
it didn't start right away. but i just kept trying after reading other people's post.
the cleaner fluid must have flooded the intake.
first 5-7 try no start.
8-13 ruff and random start.
14-17 getting normal.
18th. i just left running kept the engine hot. went around a block.
my engine idle at 750rpm vs almost zero.. before cleaning.
Old 07-23-2010, 08:53 PM   #6 (permalink)
Gameroom cash: $304255
Take the car for a 10-15 minute ride to clear most of the cleaner out of the air intake system. The car should run fine after that.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
tkkidd (07-23-2010)
Old 07-23-2010, 11:37 PM   #7 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
wow that many attempts ?!
how much did you use?
also how long were you cranking hte car for ?
CamrySExxx is offline   Reply With Quote
Old 07-24-2010, 12:41 AM   #8 (permalink)
Avy
Gameroom cash: $819455
View pmesfun's Photo Gallery
You could of also opened the throttle completely,(floor the pedal) then start it. Should turn over first time.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 07-24-2010, 01:13 AM   #9 (permalink)
it runs great now..
I'm such a noob with all this... wasn't sure pumping the pedal or flooding was the right way to go .
Old 07-24-2010, 01:39 AM   #10 (permalink)
LoudCamry's Avatar
Now seafoam your car
Old 07-24-2010, 09:04 AM   #11 (permalink)
Originally Posted by tkkidd View Post
it runs great now..
Just an FYI. You don't pump the pedal, you hold it to the floor. That's the way to start a flooded engine, same as back in the good old days.
Mike
Old 07-27-2010, 06:40 PM   #12 (permalink)
View hossmaster's Photo Gallery
Man, next time use a toothbrush to clean the butterfly. Just a squirt goes a long way.
hossmaster is offline   Reply With Quote
