LED DRLs w/ H11 base? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2010, 09:29 AM   #1 (permalink)
trehouse's Avatar
View trehouse's Photo Gallery
Anyone find any great H11 base LED's which can be swapped into the DRL's which are bright and usable as DRL's?
To do this I need a relay harness? Will the relay switch at the 6V or 8V which the DRL's run at in the standard HID relay package or do I need to find something else?
Thanks!
trehouse is offline   Reply With Quote
Old 07-25-2010, 09:58 AM   #2 (permalink)
'11 Camry
View JasonA's Photo Gallery
What year is your car? If for a 2007+, the DRLs are in the high beam segment, which use H9 bases.
JasonA is offline   Reply With Quote
Old 07-25-2010, 10:00 AM   #3 (permalink)
trehouse's Avatar
Forgot to put in my car: 2010 SE I think that it's H11 however I've never messed with my DRLs
Old 07-25-2010, 10:04 AM   #4 (permalink)
'11 Camry
H11 is the low beam segment, H9 is the high beam segment. If you want LEDs for your DRLs, you'll need to replace the high beam segment, which is an H9 bulb.
Old 07-25-2010, 10:15 AM   #5 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Do more reading and less thinking............
Old 07-25-2010, 06:47 PM   #6 (permalink)
OEM+
eyezack87's Avatar
Gameroom cash: $207080
iTrader Score: 7 reviews
View eyezack87's Photo Gallery
If you don't believe everyone, go to www.sylvania.com and look yourself
1996 Beige Lexus ES300
2010 Blue Ribbon Metallic Camry LE
eyezack87 is offline   Reply With Quote
Old 07-25-2010, 08:29 PM   #7 (permalink)
trehouse's Avatar
Gotcha, I stand corrected, H9 for high beams. I understand that they go to low voltage for the DRL's. I'm not seeing any threads about this and was looking for good suggestions on what to get.
What I'm finding via Google is that the LEDs fitting the H9's are 12V. So this wont work for DRL's w/o perhaps a relay harness I think. Here's where I'm looking for advice.
I'm looking for something like a super bright DRL like the LED DRL's on the mercedes or audi but simply in the DRL headlamp as a replacement bulb.
Old 07-25-2010, 08:35 PM   #8 (permalink)
Hello, Good Morning
ItsMeJon's Avatar
View ItsMeJon's Photo Gallery
2007-2011 High beam headlamp 9005
http://www.v-leds.com/Exterior-LED/D...-p6297704.html
http://www.v-leds.com/Exterior-LED/D...orLanding/true
If you switch your drls to leds since they are tied with high beams your high beams will not work or wont be as efficient
ItsMeJon is offline   Reply With Quote
Old 07-25-2010, 08:46 PM   #9 (permalink)
trehouse's Avatar
Thanks man. I may give these a spin unless I can find something better over the next day or 2.
Old 07-25-2010, 09:03 PM   #10 (permalink)
Hello, Good Morning
ItsMeJon's Avatar
lol good luck ive bin contemplating about that setup since i first got the car in 07 but never pulled the trigger on it since i got hids never use my drls or i use my fogs for drls.
Old 07-26-2010, 04:43 PM   #11 (permalink)
'11 Camry
Yes, thank you for that correction. I had the H11 -> H9 conversion on my mind for the low beams. The highs are indeed HB3/9005 bulbs.
