All this and no check engine light? Your MAF should throw a check engine if it goes below the resistance/temp it should read or if it's intermittent. (engine code P0110, P0111, and P0112 on most vehicles) I would def check the throttle body n clean it. Read the DIY on the forums for doing it, but you probably already have read that. The other thing, that I know of, that will kill your idle at a 'particular' rpm is your EGR valve. But you would know. If you slowly rev the engine up, @ around 1500 rpm or so (depending on the ECM settings) it will sputter and kick you down to really low rpm and then slowly build back up. To test that you would need a vacuum pump that a mechanic uses and hook it up to the EGR. Had that happen to me on an older vehicle of mine. Hope it's something simple for you to fix up! Hate it if my car doesn't run just right. Oh yeah, have you checked the camry stuff .com manual for troubleshooting yet?
