Need help removing front seats - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2010, 01:54 PM   #1 (permalink)
View Moutee's Photo Gallery
Gen6 Need help removing front seats
I recently purchased a 2008 Camry LE with water damage to the interior. The car was left outside in the Florida heat, and the interior is now moldy. The plan is to strip and replace the seats, mats, carpets, and all. The trouble is:
I cannot find a how-to for removing the front seats. I understand that they have airbags built-in, and I would rather not have one detonate in my face during the removal. I look forward to your responses, and all help is appreciated.
P.S. I did search before creating this thread.
Edit: Also, where can I find replacement carpet (not mats) for said Camry?
Moutee is offline   Reply With Quote
Old 07-31-2010, 02:40 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
If in doubt, unhook the battery, but otherwise, each is held by 4 14 mm bolts. Pull the bolts, tip them up and unplug. I suspect the dealer is the only place to get original form-fitting carpet, but any interior shop could have a go at it.
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
Moutee (07-31-2010)
Old 08-01-2010, 04:35 PM   #3 (permalink)
Thanks for the quick response, gdanaher. How do I remove the center console. Better yet, is there anyone on this board who has had to replace the carpet for their 6gen?
Old 08-01-2010, 05:21 PM   #4 (permalink)
Maven
gdanaher's Avatar
The console is connected by screws and clips which you don't want to break. Look at the repair manual which will show an exploded diagram of the console, where things are located, and how to take it apart. Way more complicated than a simple forum text message but a picture is worth a thousand words.
Moutee (08-01-2010)
Old 08-02-2010, 01:46 AM   #5 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
its 4 bolts. unplug the 2 cables that connect the seat to the electricals. and just undo the 4 bolts and you're set. It will take you 5 minutes tops.
if You want to be safe, disconnect your battery for 15 minutes, since the airbags have a reserve power supply that lasts a big longer. After you wait, then disconnect the two harnesses.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
The Following User Says Thank You to PRINCESS PEACH For This Useful Post:
Moutee (08-02-2010)
Old 08-02-2010, 09:58 AM   #6 (permalink)
Thank you gdanaher, and thank you Peach for your help thus far.
