Sealant on the top or bottom of the gasket, or both top and bottom? You can answer this question yourself. Which side of the gasket do you want the oil to leak from?
I don't know the torque value. I don't have a manual for that car, but it isn't as critical as the torque on a connecting rod. Snug the bolts up to about the same tightness all the way around in an alternating pattern, and then go over them all and make them tight, but not so tight they will break. If the pan is still on, crack one bolt just a bit and then tighten it back to give yourself a feel for how tight it is. I've never used a torque wrench on pan bolts and never will.
