2010 Camry Trunk Won't Open - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 19 Old 08-15-2010, 12:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Exclamation 2010 Camry Trunk Won't Open
Hi, I have a 2010 Camry basic model (I don't even have a button to open the trunk on the keys - I have to insert the key or use the release mechanism by the driver's seat.) This morning I found the trunk wouldn't open by either method. I can use the key to lock out the trunk (turning counter-clockwise) and return to normal mode but I can't turn more than a quarter turn clockwise.
Using the release by the driver's side seems to work (I can feel a give and hear the mechanism) but the trunk still won't open. Any ideas would be much appreciated.
rodhrrypttr@aol.com
rodhrrypttr is offline
post #2 of 19 Old 08-15-2010, 01:27 PM
2010 Camry SE V6
BlackCamSe's Avatar
Quoted: 3 Post(s)
rodhrrypttr@aol.com
are you useing the valette key?
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline
post #3 of 19 Old 08-15-2010, 01:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA
No - thanks though - I thought of that. A) My key locks the glove box so I'm sure it's the master key and B) the release by the driver's seat doesn't open it either.
post #4 of 19 Old 08-15-2010, 01:51 PM
Maven
gdanaher's Avatar
Quoted: 13 Post(s)
Assuming you are not using the valet key, and you can turn the lock 90 degrees ccw and 90 degrees cw, then is it possible that you tossed something in the trunk that jammed up the mechanism? Towel or something? Turning the key cw, push down on the top of the trunk and see if you can loosen it, and then if you can get something to give, push up.
gdanaher is offline
post #5 of 19 Old 08-15-2010, 06:37 PM
Cruisin' along
Glenn8963's Avatar
Quoted: 4 Post(s)
do you have that netting in the trunk to hols small items.......?? if so, maybe you or someone else took something out of the trunk, and it got caught on this netting, and now its jammed in the release. what i could suggest is that you use a thin piece of wood, maybe no more than say 1/2 in in thickness and lay it down on the bumper, and cover a screw driver, or use yet another piece of wood as a pry bar, and GENTLY pry up on the trunk lid as you use the key to open the trunk. if you go to the dealer i'll bet you they do the same thing, and they WILL NOT accept responsibility if they scratch anything...........
Glenn8963 is offline
post #6 of 19 Old 08-15-2010, 07:11 PM
Lost to follow up!
Quoted: 1 Post(s)
iTrader Score: 59 reviews
I fixed the title for ya!
eyeball96 is offline
post #7 of 19 Old 08-15-2010, 07:26 PM
spp
Quoted: 24 Post(s)
Does the back seat fold down?
spp is offline
post #8 of 19 Old 08-15-2010, 07:45 PM
Cruisin' along
Glenn8963's Avatar
Quoted: 4 Post(s)
i was thinking the same thing, but i think the release levers are inside the trunk.........
he could though, open the trunk, release the back seat, close the trunk and try this again however.........!!!!!!!
post #9 of 19 Old 08-15-2010, 09:30 PM
Quoted: 0 Post(s)
question: my car key dont open the trunk neither lock the glove box, how is this possible? it came with 3 keys from carmax which they're all the same
09YotaLE is offline
post #10 of 19 Old 08-15-2010, 10:05 PM
Ava_Cam's Avatar
Quoted: 0 Post(s)
they only thing i can tell you is on my 2007 avalon ( w/ the smart key) there is a small button located on the far left side when you open the glove box and there is a similar button on the camry, when that button is activated, the trunk wont open, so maybe you bumped that switch by accident, check that and let me know if it works
Black 2007 Toyota Avalon Limited White 2010 Toyota Camry LE
Ava_Cam is offline
post #11 of 19 Old 08-15-2010, 10:22 PM
Quoted: 0 Post(s)
no smart key for me
09YotaLE is offline
post #12 of 19 Old 08-16-2010, 03:35 AM
270hp = Happy Foot
Quoted: 0 Post(s)
i was too poor to add the extra feature of a smart key...if yours is an LE model, climb into the trunk, turn the release bar inside the trunk and push up.
2011 Camry SE V6 Fully Loaded w/o Navi
BC Racing Coilovers with custom 7/4kg Springs
23mm UR Racing RSB
18x8.5in Candy Red Work Emotion CR Kai's
aznlunatic206 is offline
post #13 of 19 Old 08-16-2010, 07:56 AM
Maven
gdanaher's Avatar
Quoted: 13 Post(s)
That's the point of this, bud. The seat release is in the trunk. The OP has a Catch 22. It might be possible to remove the rear seat cushion, find and remove the bolts that hinge the rear seat back, and drop it out that way. A long way to go to unlock the trunk.
gdanaher is offline
post #14 of 19 Old 08-16-2010, 10:27 AM
Ava_Cam's Avatar
Quoted: 0 Post(s)
my camry doesnt have the smart key system but it still has that button
Ava_Cam is offline
post #15 of 19 Old 08-16-2010, 12:24 PM
Senior TN Member
El Loco VG's Avatar
Quoted: 5 Post(s)
Yeah don't pry your trunk get some sockets remove your back seat and pull the safety release and see what happens but if you don't have the time for that just drive to the dealer it is a 2010
El Loco VG is offline
User Tag List
Linear Mode Linear Mode
Back
