2009 Camry LE reverse wire location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2010, 09:30 AM   #1 (permalink)
View pward's Photo Gallery
I am installing a rear view camera and I need a location of a reverse signal wire. In the 2007 Camry that wire can be found at the e48 junction. Unfortunately the 2009 e48 does not match in either wire color or pin location. Does anyone have the wiring for the 2009 e48 junction, or another location where I can find the reverse wire?
pward is offline   Reply With Quote
Old 08-18-2010, 06:42 PM   #2 (permalink)
I was able to find the wire to the back-up lights in the driver's side kick panel. It is the red wire at pin 9 on the white EN1 connector (for more details find the 2007 Camry wiring manual pdf that is floating around).
The Following User Says Thank You to pward For This Useful Post:
transmit (01-05-2012)
Tags
camry 2009 reverse wire
