Brake Lights not working ('03 Camry LE) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2010, 05:29 PM   #1 (permalink)
RBK
Gameroom cash: $105100
View RBK's Photo Gallery
After replacing the light bulbs, i still cannot figure out the problem. The back up lights still work, and the third light (rear window) still works. Any suggestions on what i should do? Trying to save $800+ dollars.
2010 Corolla S CSM A/T
2002 Camry LE A/T
RBK is offline   Reply With Quote
Old 08-23-2010, 07:12 PM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
The wiring diagram for your car can be found at www/camrystuff/com (remove slant bars, insert dots). Also you need to know if Japan or US made.
Check connector B11, in the center of the trunk floor under the latch area, might be loose. (A good place for something to snag or damage it.) I don't know if it is inside or under the car, should be inside the trunk....
Pin 1 of the light socket is +12 with the pedal pressed referenced to the chassis ground, bare metal. The other should always be ground, Ohm it to the chassis bare metal.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
The Following User Says Thank You to Luna2 For This Useful Post:
RBK (08-24-2010)
