I am trying to determine how to resolve an issue related to the replacement of the oil pan in my 2007 Camry. I took the Camry to Fred Anderson Toyota in Raleigh, NC to get the oil changed three weeks ago. The assistant service manager informed me that the threads on the drain plug and pan had been stripped during the previous oil change, which was performed at Rick Hendrick Toyota in Fayetteville, NC. He said that someone had either tightened the plug too much or used the wrong tool, and the pan needed to be replaced. He said that Hendrick should be responsible for reimbursing me for the replacement which ended up being $415.
I contacted Hendrick Toyota and delivered the parts to to them on my next trip to Fayetteville. Their service manager contacted me and said that they could find nothing wrong with the parts. He indicated that he had contacted the service manager at Anderson Toyota and discussed this. He said that the car had been "over serviced" and Anderson should give me a refund. We agreed that Hendrick would send the parts back to Anderson, and I would contact them regarding the refund.
When I contacted the service manager at Anderson yesterday, he said he had examined the parts and stood by their decision to replace the pan. He said that Hendrick was just trying to avoid responsibility. I picked up the parts from Anderson today so that they would not end up lost while I was trying to figure out the next step in resolving this.
While I was at Anderson, I bought a new drain plug so that I could compare it with the "damaged" plug. The new drain plug is about 1/4" shorter than the "damaged" one; however, the amount of thread on both plugs is identical, the additional 1/4" on the "damaged" plug is smooth. The fit of both plugs is identical on the outside of the pan, and both fit tightly. The only difference is that the smooth area of the longer one extends beyond the threaded area on the inside of the pan.I am guessing that this is the area that the Anderson service folks are saying is stripped. (SEE PHOTOS BELOW)
Further attempts to resolve this issue depend on which service department is at fault. What's the best way to confirm whether or not the replacement of the pan was necessary? Is there a way to address this with Toyota at the corporate level? My only other recourse at this point seems to going to court or filing a complaint with the NC dept of Consumer Protection, but first I would need to determine who is responsible. I would appreciate any advice on this. Thanks.
Becky
