A/C Failure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2010, 11:25 PM   #1 (permalink)
bigloubumpin's Avatar
Gameroom cash: $151645
View bigloubumpin's Photo Gallery
A/C Failure(UPDATE)
Well I noticed yesterday that my A/C is not working as designed.It's blowing warm air out the vents,also I was hearing a faint whistling sound(maybe the sound of a leak?).Ironically my wifes car (03 Corolla)did the same thing the other day but the next day started working again.Anyways with 70,000 miles on it, am I on my own with this one?
bigloubumpin is offline   Reply With Quote
Old 09-03-2010, 06:46 AM   #2 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
yes only the 36 months, 36.000 miles you are covered.
Glenn8963 is offline   Reply With Quote
Old 09-03-2010, 07:28 AM   #3 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $325400
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
I am not saying this is your problem, but, Corolla and Camry's have had some issues with the A/C relay going bad. In fact there is a TSB on them. Don't know if you have tried that yet or not, but look and see. I need to know what year your Camry is to further investigate. This may sound to easy, but I have had the complaint AC not blowing cold, and the relay has been solving the issue.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 09-03-2010, 07:48 AM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Use your Platinum 84/100/0 extended warranty............
Old 09-03-2010, 08:58 AM   #5 (permalink)
08 LE,taking it to the shop tomorrow morning.Thnx for the responses
Old 09-04-2010, 01:51 PM   #6 (permalink)
Took the car to my mechanic(not Toyota) and he said the compressor is shot.I called the dealer where I got the car and the service advisor told me that nothing can be done b/c the warranty expired(67,000 miles on it now).My mechanic called around for a compressor and got quoted $1500(the cheapest quote) and also noticed that the waterpump might be leaking as well.WTF,I'm so PISSED I dont even want to drive this car anymore.Looking to get rid of this POS next year so I'm not going to put any money into it for now. Is there a TSB for the GEN 6 waterpumps?
Old 09-04-2010, 02:01 PM   #7 (permalink)
View camryguru's Photo Gallery
not to thread jack, but my 07 camry has been at the Toyota dealership since Wednesday (9-1-2010) because the AC was not working correctly. They replaced the Compressor/Cluth, $2100, dryer $85, and now the expansion valve. AC still not working correctly, it is still blowing hot air. They are not sure what's wrong with it. They said they are going to call Toyota to see if they have had any other problems like this. Good thing I took out that extended warranty, only cost out of pocket was $70 and thats including the free loaner. Any techs on toyotanation ever see this before let me know of a solution. Thanks.
camryguru is offline   Reply With Quote
Old 09-04-2010, 02:04 PM   #8 (permalink)
I just looked and there is not any TSB for a GEN 6 camry water pump. Sorry
678-854-9601
Old 09-04-2010, 02:08 PM   #9 (permalink)
what exactly is it doing? or not doing?
678-854-9601
Old 09-04-2010, 02:12 PM   #10 (permalink)
It blows hot/warm air. they changed the compressor, dryer, expansion valve. freon levels are good. Still hot air coming out of the vents. 89,956 miles. Everything seems to be working to me, but all we get is hot air.
Old 09-04-2010, 02:18 PM   #11 (permalink)
Not sure if this TSB will help, but you can certainly ask if it may have anything to do with it. They may have already looked at it, but I don't know. It may not even be applicable, but I just typed in AC blows hot air, and this is what came up.
T-SB-0147-08: 07 Camry & 07-08 Camry HV: Rear HVAC Vents Blow Hot Air with A/C "ON"
678-854-9601
Old 09-04-2010, 06:26 PM   #12 (permalink)
Thnx Gary,cant wait unload this thing....BTW incase the pump goes what's the damage on that?
Old 09-22-2010, 01:35 AM   #13 (permalink)
View malupimp's Photo Gallery
Same problem for me.
I had this exact same issue but I took it to toyota and they did a quick diagnostic. They said that there is an A/C relay that went bad, simple fix but hard to get to so the labor portion spiked the bill a bit. Final bill came to a little under 150 bucks, hope this helps in anyway.
malupimp is offline   Reply With Quote
