Does the Gen 6 Camry's 3.5 V6 have a timing belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2010, 02:11 AM   #1 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
Gen6 Does the Gen 6 Camry's 3.5 V6 have a timing belt?
Just got a Gen 6 2009 V6 LE Camry last night. Does this motor have a timing belt or chain?......
ricamryman is offline   Reply With Quote
Old 09-03-2010, 07:54 AM   #2 (permalink)
Registered User
Gameroom cash: $161900
View hientham's Photo Gallery
timing CHAIN!!!!
hientham is offline   Reply With Quote
Old 09-03-2010, 07:55 AM   #3 (permalink)
Gen6
Originally Posted by hientham View Post
timing CHAIN!!!!
Yeahhhh!......
Old 09-03-2010, 08:47 AM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Has a timing chain which is a pluss. But u better hope ur waterpump never goes. Whole motor has to come out to get to it.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 09-03-2010, 11:26 AM   #5 (permalink)
Gen6
That's a real downer!........
Old 09-03-2010, 12:43 PM   #6 (permalink)
View xXerocXx's Photo Gallery
So more or less, whats the life of the water pump?
xXerocXx is offline   Reply With Quote
Old 09-03-2010, 06:31 PM   #7 (permalink)
Gen6
I had better get 200K minimum from the water pump!......
Old 09-03-2010, 08:08 PM   #8 (permalink)
View outsider60's Photo Gallery
!!!!!!!!!!!!!!!!!!!! Quote!!!!!!!!!!!!!!!!!!But u better hope ur waterpump never goes. Whole motor has to come out to get to it. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NOT................. About 3 hours of hard work will do.......
outsider60 is offline   Reply With Quote
Old 09-03-2010, 11:13 PM   #9 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
both my service manual and all data online repair manuals show that in order to get to the water pump the engine needs to be lifted out. Thats how Toyota dealers do it too....Its that way for all 07+ V6 Camry's. Strait from an online repair manual.
REMOVAL
1. REMOVE ENGINE ASSEMBLY AND TRANSAXLE
HINT:
See page EM-23
2. SECURE ENGINE STAND
HINT:
See page EM-30
3. REMOVE NO. 1 ENGINE MOUNTING BRACKET
FRONT LH (See page EM-35)
4. REMOVE NO. 2 IDLER PULLEY SUB-ASSEMBLY
(a) Remove the 2 bolts, 2 idler pulley cover plates and 2
idler pulley sub-assemblies.
5. REMOVE V-RIBBED BELT TENSIONER ASSEMBLY
(a) Remove the 5 bolts and V-ribbed belt tensioner
assembly.
6. REMOVE WATER PUMP PULLEY
(a) Using SST, hold the water pump pulley.
SST 09960-10010 (09962-01000, 09963-00700)
(b) Remove the 4 bolts and water pump pulley.
FR Side:
RR Side:
A129645E01
A135522
SST
A128112E03
Old 09-03-2010, 11:28 PM   #10 (permalink)
View CWH5's Photo Gallery
Not true, I have removed the entire front of the engine( Motor mount, wator pump, timing cover and chain to replace both cyl heads and cams in 5 Camry's. Yes the book does say to remove the engine but if you are a real flat rate tech you always figure out a faster way on each job. I have also replaced a ton of cams, cam box's and VVTi gears on these motors per a tsb witch says not to remove the motor but to remove the timing cover and chains and pays about 16 hrs Warranty time, i have these getting done in about 5 hrs now and not removing the timing cover or the pump as i have figured out a few nice cheats. This is how good techs make real $
actualy now that im thinking about it, i think this tsb also say's to remove the engine. dont get me wrong now, removing the pump and timing cover in the veh does take skill and is in no way an easy job. this is why i figured out a way to get the cams and boxxes out without removing the cover or the pump. This trick is also not for the average tech either and i help any of my techs who have to do this job.
CWH5 is offline   Reply With Quote
Old 09-04-2010, 12:10 AM   #11 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
That's good to hear!
GT-R is offline   Reply With Quote
Old 09-04-2010, 01:03 AM   #12 (permalink)
View coolbeans's Photo Gallery
does the 6.5gen 2.5l also have a chain?
coolbeans is offline   Reply With Quote
Old 09-04-2010, 06:59 AM   #13 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
has any1 Gen6 V6 waterpump die yet? I heard this is on the same list as the spitting oil feature and the misfire of the ignition coil. I did get both of that spitting oil and misfire and sold the car expect the waterpump feature will soon kick in.
workerant is offline   Reply With Quote
Old 09-04-2010, 04:15 PM   #14 (permalink)
Gen6
What is the "Spitting Oil Feature"?.............
Old 09-04-2010, 06:37 PM   #15 (permalink)
Did you watch James Bond 007 movie? During a chase and James press a button in his car to release a massive amount of oil onto the road? Well, the '07 Camry added that feature because it's 2007 matching with 007. But they don't provide U with a button, instead it just happen randomly.
Seriously though, it's the oil line burst defect and it is one of the recall too.
