2011 SE 2.5 humming noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2010, 12:48 AM   #1 (permalink)
View redse's Photo Gallery
Just bought a 2011 camry SE few days ago. My first 4 cylinder car, but is it common for this car to have this electronic humming sound when i press the gas pedal?
I called the dealer but they said it will go away after the breaking period...
Is this true? I test drove a different 2.5 before I chose this one and I don't remember hearing anything like this.
redse is offline   Reply With Quote
Old 09-12-2010, 12:54 AM   #2 (permalink)
min2patl's Avatar
Gameroom cash: $169300
View min2patl's Photo Gallery
My 2.5L SE has the same thing.... when i was picking the car at the dealership. I test drove 3 of them and they all sounded the same. Sounds like an electric supercharger lol
min2patl is offline   Reply With Quote
Old 09-12-2010, 04:35 AM   #3 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
Does the level of the sound or whine get louder after you have been on a moderately long run, then stop and when you start to move from the stop, it changes with the engine RPM?
I have this type of problem, changes volume and pitch with RPM, loudest when hot.
My whine was located last month by another dealer as I was leaning toward a transmission issue.
It was diagnosed as a bad power steering pump, mine was peaking at between 2,200 and 2,800 RPM. I am scheduled in to have it replaced this Tuesday.
The Tech isolated it by removing the serpentine belt.
I will post an update later.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 09-12-2010, 07:50 AM   #4 (permalink)
'11 Camry
View JasonA's Photo Gallery
Mine has a touch of a "whine" noise, but it's pretty quiet. I can hear it if I have the radio off and the windows down. Otherwise, with normal sounds of radio and HVAC, etc, it's not really that loud. If you can hear it with everything going (if it's that loud), then it's probably not normal. I drove two different 2.5L 2011 Camrys (mine was the second one I drove) and neither had an obvious whine sound to it.
JasonA is offline   Reply With Quote
Old 09-12-2010, 08:39 AM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
I have a 2011 XLE and I hear mine in the background, with the radio set to a "7" and the automatic climate control blower speed is 2 steps below max.
I feel that the sound is being transmitted through the steering wheel shaft into the cabin. I couldn't hear it with the windows down, too much other noise. It sounds very similar to an alternator whine from the radio, but I couldn't turn it off with the radio......
MFG 02/25/2010
Stock, Shucks!
Old 09-12-2010, 01:04 PM   #6 (permalink)
when i test drove, it was hot so the a/c was pumping all the way, that's probably why I didn't hear it. Also, who would of thought a new car would make this kind of noise.
Even after a long highway ride and as i exit out and stop and go, it's pretty loud. It is like a kid whining. My thought was something to do with the alternator but i will bring it in next week.
Old 09-14-2010, 06:47 PM   #7 (permalink)
Twin & (1 of 8)
Luna2's Avatar
After a 160 mile round trip, $17.00 toll, no repairs were done.......
This was after i was notified or told both parts were in.... A total of two trips for problems and nothing was fixed, might be looking for another dealer.
MFG 02/25/2010
Stock, Shucks!
Old 09-15-2010, 03:57 AM   #8 (permalink)
View 94PrizmDD's Photo Gallery
your dealership is 80 miles away?
94PrizmDD is offline   Reply With Quote
Old 09-15-2010, 04:30 AM   #9 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Correct, the closest one that I purchased my 07 Camry from, kept messing things up. The problems they created would only occur after about 90 days and 1500 miles. The big one was the warping of the rotors after a tire rotation, over torquing the lug nuts. After 3 times getting them fixed, I wouldn't trust them with a roller skate, they were repaired two times at another dealer while traveling, and were beginning again. (Try to prove that one.) I dumped the car for a new one with extended warranty. I had other issues with other vehicles they couldn't fix, one was a bad cruse control switch and the other was a bad sensor in the ignition system. Each of the replacement parts cost less than $20.00.
MFG 02/25/2010
Stock, Shucks!
Old 09-17-2010, 05:36 AM   #10 (permalink)
'11 Camry
What parts were they going to replace?
Old 09-17-2010, 11:36 AM   #11 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Plus the electronic (EC) mirror which was just loose on it's mount. I torqued it at home, after it was "serviced".....
MFG 02/25/2010
Stock, Shucks!
Old 09-19-2010, 07:01 AM   #12 (permalink)
'11 Camry
Duh. I can't read. Let us know if that fixes the noise!
Old 09-19-2010, 10:23 AM   #13 (permalink)
Twin & (1 of 8)
Luna2's Avatar
I have escalated all of the issues to the corporate level, they were to contact me on September 17, but have not. I have received no updates from the dealer either....
I will be on travel for the next 2 weeks, but in contact. I will post any updates.
(I copied and pasted rather than explain it again and it was faster, not a good typist. Sorry.......)
MFG 02/25/2010
Stock, Shucks!
Old 10-14-2010, 07:00 PM   #14 (permalink)
Twin & (1 of 8)
Luna2's Avatar
The "whine" in the 2.5L is an issue with all gen 6.5's according to the corporate representative I talked to today. A test drive of a brand new LE confirmed the issue. I hope Toyota will provide a resolution to this apparently "wide spread issue".........SOON. I have the full coverage extended warranty, no cost, just very annoying. I tried to see if the gen 6 2.4L power steering pump is interchangeable with the gen 6.5 2.5L, without any luck. I will have to wait till next summer while on vacation...... To many other commitments between now and then.
MFG 02/25/2010
Stock, Shucks!
Old 10-15-2010, 09:18 AM   #15 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
The new Camrys have lots of little noises all the time.....it's annoying but I just crank the radio and forget about it. I spent so much time fixing every little thing on my last car that I don't want to even bother messing with this one. lol
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
