unprogrammed key starts engine of camry 2004 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2010, 06:46 PM   #1 (permalink)
View nasoni's Photo Gallery
USA unprogrammed key starts engine of camry 2004
Hi, two days back I closed the trunk of my Camry (2004) after getting a water bottle and i realized that the key is inside the trunk. I did not have duplicate key so i went to Toyota Dealer this morning and asked for duplicate key. Upon producing all the necessary details ( VIN/ proof of ownership/ID), I was told that I will get the key which can open the doors only but will not start the car. After having that key spending just $6.58 I reached home and unlocked the trunk and got my Original Key back.
Just to verify that this duplicate key does not start the engine, I inserted the key in the ignition and tried to start the car and guess what, It started the engine with no complains. After few seconds I turned the engine off and used the Original key and it worked too as expected ..
Now i am not sure that using Duplicate key to start the engine will make any damage to my car's engine/computer at any point..
Has any one any Idea or comments ?
nasoni is offline   Reply With Quote
Old 09-13-2010, 07:38 PM   #2 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
was the unprogrammed key linked onto the same key chain?
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 09-13-2010, 07:39 PM   #3 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
im going to assume your camry is a base model? LE ?
It sounds like you dont have the engine immobilizer.
If it starts , your fine, it wont damage anything if you use it.
IF you DID have the engine immobilizer, the car would just crank and crank but it wouldnt start. That's what the immobilizer does, it prevents the car from actually starting. So it prevents it from getting started, but onec its started the immobilizer cant do anythign to prevent the car from getting stolen etc.
here is a good example
So pretty much if the new key starts the car, its fine.
CamrySExxx is offline   Reply With Quote
Old 09-14-2010, 09:14 AM   #4 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Unless the Camry is like other cars out there and will just shut off the fuel pump after a few minutes when it doesn't detect the programmed key. That way, if someone steals your car, they'll make it about a block or two before it just dies.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 09-14-2010, 10:17 AM   #5 (permalink)
^Never seen cars like that and I have looked at quite a few main relay diagrams of toyotas. I am a mobile security/remote start installer.
Old 09-14-2010, 10:56 AM   #6 (permalink)
Need For Speed
Oh well pretty much every GM/Ford car out there has that feature now....my 2004 Mustang had that feature......it all started with Cadillac about 20 years ago when they started putting chips in their keys. If you didn't have a chip in the key the car would start, yes, but only make it about a block or two before the computer shut off the fuel pump. I am very familiar with GM/Ford in that respect and wasn't sure if Toyota would do something similar. They should.....
Old 09-14-2010, 12:53 PM   #7 (permalink)
View 94PrizmDD's Photo Gallery
What a deal $.6.58 ! I remember when i lost my keys to my prizm the dealer charged me $75 for a duplicate. So even a key just to open all the doors at the price is great lol. You must have a honest dealer. Drive the car around your block, see if it turns only way to find out.
94PrizmDD is offline   Reply With Quote
Old 09-14-2010, 01:01 PM   #8 (permalink)
on star?
and its just a basic engine immobilizer, like i said once you get it started, your good to go.
Old 09-14-2010, 01:29 PM   #9 (permalink)
Need For Speed
It has nothing to do with onstar....just the computer senses there isn't a chip in the key and shuts off the fuel pump. Like I said before I didn't know if Toyota had that in all their cars or not.
Old 09-14-2010, 01:42 PM   #10 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
Gen 5's dont have chips in their keys. So if you get a blank key cut, it will start the engine. A friend bought a flip key for his Gen 5 SE, went to a store to get cut and also got a blank house key cut for his car. Both started the car without problems.
CarDomain
Old 09-14-2010, 03:17 PM   #11 (permalink)
late 1990, most upper trim package toyota have chip in their keys. I have installed remote start on a lot of them. We used to own an 02 V6 LE and it does it have it. It also had remote start w/ a bypass.
Old 09-14-2010, 03:41 PM   #12 (permalink)
http://www.youtube.com/watch?v=MaYbcC8yJdo
Thanks for the reply ! Yes it's Camry LE ..
Old 09-14-2010, 05:49 PM   #13 (permalink)
Gameroom cash: $304255
"late 1990, most upper trim package toyota have chip in their keys."
^ I believe what profuse007 is talking about are the generation 4, 5 and 6 XLE models, which come from the factory with an alarm system and an imolbilizer. They have a chip in those keys. I have owned a 98 XLE and currently own an 07 XLE. Both cars had alarms and imobilizers with keys that had a chip in them.
Mike
Old 09-15-2010, 09:18 PM   #14 (permalink)
Some do , some dont.
our gen5 does.
Tags
camry 2004
