Checking Gen 5.5 Coolant levels - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2010, 08:11 PM   #1 (permalink)
Gameroom cash: $137274
View johnfrisco's Photo Gallery
What should the coolant level read on a 2006 Camry 4 Cylinder when the engine is cold. Does it have to be exactly at Full or is an inch or 2 below okay?
I brought in my Camry to a quick service station over the weekend and they noted they added coolant—have no idea on how much they added.
My car has 35K miles and am concerned about #1 the Head Bolt Issue; #2 the Water pump issue.
So what gives the most accurate reading of coolant levels? Thanks!
johnfrisco is offline   Reply With Quote
Old 09-13-2010, 08:24 PM   #2 (permalink)
canderton01's Avatar
View canderton01's Photo Gallery
The level will vary as the radiator heats up and cools down. As long as it doesn't get below the "low" mark on the overflow reservoir or unless you notice a sudden drop like right after you fill it up, you should be fine.
2002 XLE I4
canderton01 is offline   Reply With Quote
