after going through and replacing the spark plugs, O2 Sensor, Cleaning the MAF, and some fuel system cleaning solution to the tank it never changed anything. i don't have the MIL on anymore but had the rough idle still. It turns out my PCV Valve was shot, so i replaced it and didn't do anything. I just took it in a few days ago to a shop and had them clean the entire air intake. When the PCV Valve stopped working it caused Oil to end up in my air filter and all over the intake manifold. So about the MIL, change the O2 Sensor, and if you still have a rough idle then check and see if your intake is caked in oil and dirt. Replace the PCV Valve and have the intake manifold, and throttle body cleaned. Toyotas in general are known for having this problem. also when you clean it out check your Throttle Position Sensor (TSP) and make sure it is not failing either. Mine has cleared up, but my friends same camry just had the P2238 Code at 151,239. Same rough idle problem.
5th Gen 04 Camry LE I4
91500 Miles
SE Headlamps
16" rims
(Stock Toyota Camry Hybrid)
