Exclusive's LED "fog light" mod - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2010, 12:54 PM   #1 (permalink)
'11 Camry SE
exclusive's Avatar
Gameroom cash: $305680
View exclusive's Photo Gallery
Gen6 Exclusive's LED "fog light" mod
Here is my LED "fog light" mod that sort of resembles the new benz's. I didn't want to mess with cutting into the covers so I ran them right below. I tapped into the headlight fuse so they turn on with the headlights. Took a while to do but I'm very happy with the way it came out
Vid:
2011 Camry SE
|| Click my car below to see my thread ||
exclusive is offline   Reply With Quote
Old 09-18-2010, 05:05 PM   #2 (permalink)
View pRzNiMaN's Photo Gallery
DIY this shit
it looks chill
i have an 11 SE so i have fogs
but i think it would look tight under the fogs, u think?
pRzNiMaN is offline   Reply With Quote
Old 09-18-2010, 07:35 PM   #3 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
looks good.
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 09-18-2010, 08:04 PM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $952915
iTrader Score: 16 reviews
Nice job. Very subtle. Suits well too
Old 09-18-2010, 08:08 PM   #5 (permalink)
2011 CAMRY SE
View cuzz22's Photo Gallery
Thumbs up
Vid:
that looks sweet..just might have to do that to my SE...
cuzz22 is offline   Reply With Quote
Old 09-19-2010, 01:54 AM   #6 (permalink)
SSBN's Avatar
View SSBN's Photo Gallery
Looks great. I have seen several new MBs driving around and I like the look. Nice job.
'08 XLE V6 Magnetic Gray, Nav, leather, Heated seats, VSC/Trac, Smart key, Remote start,K&N,35%front/5% rear tint
SSBN is offline   Reply With Quote
Old 09-19-2010, 03:19 AM   #7 (permalink)
View AloRock's Photo Gallery
Looks better than all those standards. Where did you buy them, do you have a link for us ?
Camry LE 2.5 Iguan 2010
AloRock is offline   Reply With Quote
Old 09-19-2010, 09:47 AM   #8 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
That looks sweet. Make a diy. I'd like to do this mod.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 09-19-2010, 05:01 PM   #9 (permalink)
OEM+
eyezack87's Avatar
Gameroom cash: $207080
iTrader Score: 7 reviews
View eyezack87's Photo Gallery
Most likely he tapped into the +/- wires of the headlights and extended it to the LEDs, which should run on 12v of power. Its the same general idea in adding foglights to a car that didn't have them to begin with, minus the switch
Looks good OP. I was considering making some fresh with 5-chip LEDs to make sure they last but got sidetracked by the ES300 projector fogs I'm working on right now
1996 Beige Lexus ES300
2010 Blue Ribbon Metallic Camry LE
eyezack87 is offline   Reply With Quote
Old 09-19-2010, 05:30 PM   #10 (permalink)
'11 Camry SE
exclusive's Avatar
Thanks for the compliments everyone
Basically on ebay they have tons of these items in different lengths and colors...it's just two LED strips.
I wired each LED strip to one another, and then ran a wire from the + side of the LEDs to the 15A low beam fuse (only on the fused side; only 1 of the fuses).
I ran the - side of the LEDs to a bolt in the engine bay for ground.
The LEDs just stick on with the given 3M adhesive.
Just requires some soldering, shrinkwrap, & flex tubing. I made my own fuse tap taking apart an old maxi fuse. You can get a mini fuse tap from online, but I didn't want to wait.
You will need to unscrew/unclip the splash guards from underneath your bumper so you can have access to run the wires. The screws and clips are easily noticeable and easy to remove.
Note: In my case, the LED strip did not show which wire was +/-. I just tested the strip by touching the wires to the battery and figured it out that way.
2011 Camry SE
