2008 Camry CE Manual Viper Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2010, 02:57 PM   #1 (permalink)
View tcflint's Photo Gallery
Ok, so it sounds like adding OEM keyless is about impossible so I am going to go with the Viper 5701.
I got a spec sheet with and I assuming the wire colors are that of the Camry and not the viper?
Also this is going into a 5 speed car, how have you guys made out with this option?
Also the spec sheet talks about taggin onto a fuel injector wire instead of or for the tach reading. Sound familiar????
Thanks guys.
tcflint is offline   Reply With Quote
Old 09-21-2010, 03:25 PM   #2 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
mine as well get this.
http://toyotapartspeople.com/SearchP...ecurity+System
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is online now   Reply With Quote
Old 09-21-2010, 03:41 PM   #3 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
#513592: 2008 TOYOTA CAMRY 4DR SEDAN
All Door Trigger BROWN (-) AT VEHICLE FUSEBOX
Trunk Trigger WHITE (-) AT BECU MODULE IN VEHICLE FUSEBOX
Hood Trigger RED (-) AT VEHICLE HOOD PIN SWITCH
Parking Lights BLACK (-) AT BECU MODULE IN VEHICLE FUSEBOX
Parking Brake YELLOW (-) AT PARKING BRAKE SWITCH
MAY ALSO BE BLUE ON SOME MODELS
Battery BLACK (+) IGNITION SWITCH HARNESS
Ignition 1 YELLOW (+) IGNITION SWITCH HARNESS
Ignition 2 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 WHITE (+) IGNITION SWITCH HARNESS
Starter 1 BLUE (+) IGNITION SWITCH HARNESS
Starter 2 GRAY (+) IGNITION SWITCH HARNESS
Key Sense BLUE (-) IGNITION SWITCH HARNESS
THIS WIRE WILL DISARM THE FACTORY SECURITY WITHOUT UNLOCKING THE DOORS
Tachometer BLACK (AC) AT DATALINK CONNECTOR UNDER DRIVER DASH
Power Unlock GRAY (-) IN HARNESS IN DRIVERS KICKPANEL
USE A DOUBLE PULSE TO UNLOCK ALL DOORS
PowerLock BROWN (-) IN HARNESS IN DRIVERS KICKPANEL
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 09-21-2010, 03:43 PM   #4 (permalink)
Viper has the MT sequence. study the manual.
all injectors have a common color wire and individually have a unique color. tap to any unique color. you can still use the tach wire listed above.
Old 09-21-2010, 08:04 PM   #5 (permalink)
Originally Posted by BlackCam09 View Post
This works with one without keyless entry from factory? Is there a reciever also?
Old 09-21-2010, 08:06 PM   #6 (permalink)
Yea, I did look over it and it seems pretty good, just wondering how your personal experiences were...
Old 09-22-2010, 07:38 AM   #7 (permalink)
007, These are all the ones you used? Is your car 5-speed also?
Old 09-22-2010, 10:05 AM   #8 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
installed the remote starts , 5101 on a gen 5 camry auto , and 5501 on the gen 6 auto,
and a 5301 (same as 5701 but no alarm) on my manual accord.
You CAN change it from manual mode to AUTO, but just be VERY careful not to have your car in gear. Also you will most likely need an immobilizer by pass.
I have all my sheets and wiring on paper at home, im off at school right now but i will have access this weekend if you need any help.
CamrySExxx is offline   Reply With Quote
Old 09-22-2010, 10:24 AM   #9 (permalink)
so damnit i cant find my video files of my gen6 when i backed my stuff up. But I have my gen 5 videos , maybe ill post them up. VERY similar wiring in the cars if not that same
Old 09-22-2010, 01:07 PM   #10 (permalink)
I guaranteed you that the information is reliable and correct. I used to use the source regularly w/o any problems. Mobile security/RS is one of my expertise.
my SE is not 5spd. For 5spd, you need to switch from MT to AT mode on the viper, hook clutch, and e-brake. Those are the only different for MT car from AT cars.
Old 09-22-2010, 07:19 PM   #11 (permalink)
Sounds good, you can't get too much information on these projects and compile the best of everything...
Old 09-22-2010, 07:20 PM   #12 (permalink)
That's cool. Thanks for all you help and I definetly not shortcut the MT mode and hope that I took it out of gear
Old 09-22-2010, 10:30 PM   #13 (permalink)
I meant make sure the mode is in MT, it should be at default. the routine prevent you from putting car into gear.
Old 09-22-2010, 11:02 PM   #14 (permalink)
yea ill take a look this weekend, i took a quick look earlier and cant find my gen6 install vids , only the gen 5 but its very similar,
my tip, GET A GOOD 12V TEST LIGHT!
The wires (ign , starter , +12v etc) are very thin and arent a thicker gauge as expected, and wit ha bunch of wires the same colour , you must check each individual wire!
also manual mode, if i remember correctly, you are required to ... hit the brakes, while holding it, pull the ebrake, hit the remote start button on your key fob, remove the key, get OUT of the car. your car will still be running, once you lock the door the car will shut off ensuring you were able to leave your car and turn it off from the outside to make sure its in neutral.
its good , but a pain, like if u needed to run into your car and open the door, you just resetted the sequence and must re do it to start your car the next time you want to
Old 09-23-2010, 07:26 AM   #15 (permalink)
^that's a bad tip, man. Get a Digital Multimeter (DMM) not a test light.
If you need further information, go to www.the12volt.com.
