Well, I have pictures, but the forum doesn't allow me to post them.
So here's the story.
I have a 2007 Camry XLE with the JBL sound system. I got the car last year and noticed when the weather was cold one of the rear speaker buzzed like crazy. Not just a buzz, but with very distorted midrange and missing low frequencies, especially at low volumes. Crank it up loud and it almost sounded OK I put it off until summer...
It got warm, and the buzzing was gone. It just suddenly fixed itself. Well, it's Fall. So, I tore the interior apart to take the speaker out. It's definitely the speaker as it does the same thing indoors on a different stereo system. I pushed around on the cone and noticed that it would start sounding fine if the spider was just pushed to one side. Well, that could be a voice coil with windings that came loose from excessive heat. BUT, it moved smoothly with a wide range of offsets to one side. Normally a shot voice coil takes up more room in the gap and its very difficult to get it to not buzz.
It seemed more like the voice coil (and spider) just weren't centered together. I played and played and eventually peeled the spider from the frame. Then I noticed something. The magnet wasn't pushed completely against the frame. There was a gap around the seam between the magnet and the frame on one side, causing the magnet to be tilted. I clamped the edge of the frame and magnet tightly in my hands and "CLICK" it sat down flush. The speaker started working much better. I twisted it and pulled it back off a bit and the performance was worse. I used some thin CA (super glue) to glue the magnet down tight. Now I still have to glue the spider back on without screwing it up.
If I could do it again, I'd leave the seats, deck, trim and speakers right where they were, climb in the trunk, and push up on the magnet hard or squeeze on the edge of the frame and the magnet tight. I believe that would have been the 5 minute solution. Maybe this will save someone else from replacing an expensive speaker or just not listening to the stereo.
