Can '04 Camry 4cyl Rotors be Resurfaced? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2010, 11:03 AM   #1 (permalink)
View i_am_jim's Photo Gallery
Question Can '04 Camry 4cyl Rotors be Resurfaced?
My '04 Camry brakes are pulsating. In my experience this is usually caused by rotor problems. In the past I would get rotors resurfaced. I read somewhere that today's rotors cannot be resurfaced.
Can the rotors on my car be resurfaced?
Two Camrys. '94 6cyl & '04 4cyl
i_am_jim is offline   Reply With Quote
Old 10-03-2010, 11:30 AM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Today's rotors have very little excess metal that they often reach minimum thickness first. However, if yours are still above the minimum thickness then yes then can be resurfaced. Provided that they can last the current set of pads and still be above the minimum.
Toyota is having a lot of problems with Gen5+ rotors, so what you're experiencing is not unusual. Toyota also had replaced some brake pads. Maybe they were substandard as well. When you remove the pads, let us know what codes are printed on the back.
If you need to change rotors/pads, I'd get Raybestos Advanced Technology rotors with Akebono ProAct ceramic pads. At this time, I don't see the excellent Brembo rotors available, but they should be in the years ahead.
Old 10-03-2010, 02:51 PM   #3 (permalink)
These two number are on the back:
5610DA
PA533-EE
My parts house says they have Brembo rotors. When you say "the excellent Brembo rotors" are you saying they have different grades, or is it you just don't see Brembo rotors? If there are different grades, which ones are you talking about?
Old 10-03-2010, 03:48 PM   #4 (permalink)
schott1984's Avatar
View schott1984's Photo Gallery
Can anyone else vouch for these pads and rotors he recommended? I'm going to order some for mine...
2007 Camry SE V6, JBL, Sunroof... Purchased Oct. 1, 2010 with 75k miles.
schott1984 is offline   Reply With Quote
Old 10-03-2010, 05:47 PM   #5 (permalink)
schott1984's Avatar
Gen6
Well, anyway... I ordered those pads and rotors. Rotors from rockauto, pads on ebay. The pads were cheapest there.
I only need the rears done right now, 2mm left on pads according to previous owner's Toyota inspection a week ago.
Old 10-06-2010, 07:29 PM   #6 (permalink)
schott1984's Avatar
Put the akebono pads and raybestos rotors on my rear brakes tonight. Did a little test drive, seems ok. Wasn't much of a problem other than the pads were wearing out though, haha.
