The Venza and Camry's wheel base is a different size, meaning if you swapped wheels, you would just have to get the correct tire size for the Camry or you will rub.
Assuming you did this, the wheel offset would be .5.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
i know the the tires are way to big
but do they have the same offset? adn bolt pattern
but the 20s would look good withj some low pros on em
even the 19s
2011 camry SE (white)
2.5
lookinn freshh
even the 19s
The Venza is 5x14.3, 12x1.50 lug, 30-38mm.
The Camry is 5x14.3, 12x1.50 lug, offset 34-45mm.
The offset will be off by .5 if you go with Venza wheels. (the only reason why I say that, is b/c I just called the local Toyota parts dept out of curiosity.)
offset is just a number if its just alone...
its valuable information when you pair it up with the width of a wheel/rim
Also the bolt pattern is 5x114.3 , and the offset on a particular rim is a specific value not a range.
hrm the specs i could find for the 20" wheel is ...
20x7.5 +35mm offset.
The stock SE wheel is a 17x7.5 +45 (gen6) correct? This is from memory from what i remmeber form a year ago...
The wheel will sit 10mm out more, you might wanna ask the wheel gurus, im pretty sure it would fit though, i would say it would fit the rear since the rear is pretty tucked right now. The front ... Im not gonna predict anything , try asking lammy, pawel, peach or ... the rim thread.
