Rough Idle L4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2010, 12:14 AM   #1 (permalink)
View OddJack's Photo Gallery
Rough Idle L4
I had very poor idle and car running shakey. Engline light came on. I changed the spark plugs NGK IR and it was good for couple of days but then again the shaky idle comes back. It feels like one of the cylinders not firing. No maintenance done last 30000 miles, car has 99k miles.
What else can I change?, What would be the equivalent of spark plug wires?
OddJack is offline   Reply With Quote
Old 10-04-2010, 12:34 AM   #2 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
might be getting flooded. make sure the plugs aren't over tightened and torqued to the right specs. might be the coil too.
check which one of the plugs is black and that's the one that's getting flooded.
Redline_Me is offline   Reply With Quote
Old 10-04-2010, 09:11 AM   #3 (permalink)
How often is the coil changed? every tune up? How hard is it to change it?
2002 L4 Camry
Old 10-04-2010, 12:11 PM   #4 (permalink)
not often at all. But if you're having problems than why not, you got some miles on that thing so do a full tune up.
Old 10-04-2010, 12:23 PM   #5 (permalink)
Gameroom cash: $245200
View fatngs's Photo Gallery
i work in auto parts and i kno that coils arent cheap on that engine so i would get the check engine light diagnosed first.... if its a cylinder misfire it will tell you which one
fatngs is offline   Reply With Quote
Old 10-04-2010, 02:57 PM   #6 (permalink)
Yes, very expensive. Over $250 for a set.
I just ordered a obd II reader.
Old 11-11-2010, 11:43 AM   #7 (permalink)
View jbbnet's Photo Gallery
you should be able to determine which coil it is by the code, but which coil is for which cylinder? Does the v6 camry 2grfe use one coil for a pair of cylinders?
2010 VW Jetta TDI
2008 M5 w/SMG Space Grey on Black, Breyton GTS 19's
2007 Camry SE V6 Black on Black
1998 Lexus GS400 Spectra Mica, SSR staggered 19's, Apexi World Sport Series exhaust, TRD Suspension, L-Sportline 1.75"
1997 Tacoma LX
jbbnet is offline   Reply With Quote
Old 11-11-2010, 08:43 PM   #8 (permalink)
View joshuaboston's Photo Gallery
auto zone will read the code for free.
I would also check to make sure all your coils are in properly. Perhaps buy some dielectic grease and add a bit to each coil... where it contacts with the spark plugs.
joshuaboston is offline   Reply With Quote
Old 11-11-2010, 08:43 PM   #9 (permalink)
goog luck
Old 11-13-2010, 02:49 AM   #10 (permalink)
View TOYO-ED's Photo Gallery
Perhaps the IAC valve is dirty?
Check this link to see further details:
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
TOYO-ED is offline   Reply With Quote
