2008 se manual - leaking gear fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2010, 03:31 PM   #1 (permalink)
View joshuaboston's Photo Gallery
Hey people,
I just purchased a 2008 Camry from Craigslist with an extended guarantee.
I brought it to a dealership for an oil change and they have informed me that I am leaking gear fluid (transmission oil). The person told me he is not sure where it is leaking; it could be between the drive shaft and the transmission.
I could not find anyone else with this problem.
I am scheduled to have a thorough diagnostic done to the car this Friday.
Any thoughts on this matter?
Thanks.
joshuaboston is offline   Reply With Quote
Old 10-05-2010, 03:36 PM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
"Extended guarantee" off Craigslist? How does that work? If that's the case wouldn't you get it taken care of through that? I have a 2011 SE manual, but it's a different engine and trans. Manual Camry's are hard to come by. Probably just a seal went....though it could be worse.....tell them to put a little dye in the fluid, then you will be able to tell where it is coming from.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 10-05-2010, 03:44 PM   #3 (permalink)
About the guarantee... when you purchase a "platinum extended guarantee" through Toyota, it is transferable to the second owner of the car for $50.00 and must be done within the first 30 days of ownership. I guess this is a selling point to purchase the guarantee.
I purchased the car with 35K mile for $13K (car now has 37k miles), came with a sunroof, no stability control J, fog lights and stick shift and the remaining extended guarantee 7 years or 75Kmiles.
Old 10-05-2010, 03:47 PM   #4 (permalink)
Need For Speed
Ahhhh I get it now, thanks for clearing that up. Like I said, try throwing some dye in the trans (I believe there's a plug for adding fluid somewhere on top or near the top of the trans), and see where it leaks out.
Old 10-05-2010, 06:05 PM   #5 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
well the entire underside should be cleaned/de-greased, then a dye put in, then you drive for about 1 week, then you go back.
at least 2 places the leak id from, axle seals or input shaft.
axle seal leaking, under warranty they will replace only the leaking one, and its a pretty quick job.
input shaft.........transaxle removal........big job, no car for one, maybe 2 days.
Glenn8963 is offline   Reply With Quote
The Following User Says Thank You to Glenn8963 For This Useful Post:
joshuaboston (10-05-2010)
Old 10-06-2010, 11:41 AM   #6 (permalink)
View mcdawgg's Photo Gallery
Originally Posted by joshuaboston View Post
Hey people,
Thanks.
My 2007 CE 5 speed manual had a bad O-ring seal on the output shaft - started around 5 or 10 thousand miles, very very small leak. They replaced the seal under warranty in about 2-3 hours total. I posted a picture of it on Toyota Nation - search for it and you'll see it.
mcdawgg is offline   Reply With Quote
Old 10-06-2010, 02:31 PM   #7 (permalink)
Need For Speed
Wow, bad o-ring seal, water pump went early....keep an eye on that Camry of yours...although I admit water pumps go out early on 75% of Camrys/Corollas
Old 10-06-2010, 03:19 PM   #8 (permalink)
I would really like to see this post and pictures but I could not find it.
Old 10-08-2010, 11:42 AM   #9 (permalink)
Oil Leak!
Here you go...
The Following User Says Thank You to mcdawgg For This Useful Post:
joshuaboston (10-08-2010)
Old 10-08-2010, 11:52 AM   #10 (permalink)
Yes, I also had the dash rattle (TSB took care of that) and the hesitation on acceleration (TSB also done). The hesitation was strange, because it is a manual transmission. When I bought it, I knew the automatics had the hesitation, but it turns out the manual had the hesitation too!
No problems since, but the water pump worries me - when will it fail next?? All prior cars went at least 100,000 miles on the water pumps!!
Old 10-08-2010, 12:13 PM   #11 (permalink)
Need For Speed
I see in our service department all the time cars come in around 25-35k with bad water pumps. Warranty took care of it of course, but all the same, a big job that no one likes. My old car went 125k on the original water pump.
There's a TSB on the dash rattle??? I'm going to look into that....
Old 10-08-2010, 12:49 PM   #12 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Yes, but my fix was to stuff some foam rubber down by the base of the dash where it meets the windshield. No more rattles and didn't have to have anyone disassemble half the car.
gdanaher is offline   Reply With Quote
Old 10-09-2010, 10:46 AM   #13 (permalink)
I want to thank everyone for posting.
I brought it to the dealership and they confirmed that it was the same gasket that was mentioned. And of course they do not have it in stock.... and now I have to go back.
Everyone at the dealership was really nice BUT THIS IS BULL SH*T THAT I HAVE TO COME BACK.
I was there last week to get an oil change... (express garage) where they noticed it... yesterday I went to another garage (next door to the express garage) and it took the guy like 20 seconds to say "YUP you need to change the gasket on the drivshaft".
I just think that is the DEALERSHIPS actual put the customer first this sort of stuff (coming back all the time) would not have happened. I'm a little disappointed.
I will post again when the job is done, and one more time when I DIY oil change and examine that I have a dry undercarage.
Thank you.
Josh
Old 10-09-2010, 11:47 AM   #14 (permalink)
Maven
gdanaher's Avatar
Manual transmissions in a Camry are very rare. The dealership needs to stock parts used daily or weekly, not once in a blue moon. The parts are at the regional warehouse and they can get them in a day or two. If they are being nice to you, understand that each dealer is not in a position to be a stocking warehouse for all parts for all models, and that they are probably doing the best they can.
Old 10-09-2010, 11:55 AM   #15 (permalink)
Need For Speed
I work at a dealership and anything involving the trans on a manual Camry takes a couple days to come in. And expecially with the new 2010/2011 6 speeds sometimes they even have to special order it. (No one seems to carry parts for it!!! lol)
Tags
gear fluid, transmision leakage, transmission oil
