> 80 MPH my Steering Wheel starting vabrating... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2010, 11:47 PM   #1 (permalink)
ptt1404's Avatar
View ptt1404's Photo Gallery
a
ptt1404 is offline   Reply With Quote
Old 10-07-2010, 12:08 AM   #2 (permalink)
View pRzNiMaN's Photo Gallery
do you have an SE?
2011 camry SE (white)
2.5
lookinn freshh
pRzNiMaN is offline   Reply With Quote
Old 10-07-2010, 12:12 AM   #3 (permalink)
11LE's Avatar
Gameroom cash: $243600
View 11LE's Photo Gallery
I think you mean speed, so MPH. MPG is your mileage and how many miles you get per gallon of gas.
It could be unbalanced wheels, a bad bearing, or sticking brakes. My bet is on the first one.
Super White 2011 LE
|Debadged|-|4300k HID's|-|Tinted|-|Wheel Pkg|-|OEM Tip|-|Covered Squirrel Spotters|-|Yakima Rack System|-|Illuminated Cup Holders|
11LE is offline   Reply With Quote
Old 10-07-2010, 12:21 AM   #4 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
MPG?
It's most likely the balancing. Do you have aftermarket wheels? If so, then you might need to get some hubcentric rings to eliminate the vibrations at high speed.
GT-R is online now   Reply With Quote
Old 10-07-2010, 12:30 AM   #5 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
I had an off-balance wheel/tire and the steering wheel vibrated like crazy around 50-60 "MPG"
Dave-o is offline   Reply With Quote
Old 10-07-2010, 12:39 AM   #6 (permalink)
its all about the SE handling hahahah
2.5
lookinn freshh
Old 10-07-2010, 12:39 AM   #7 (permalink)
ptt1404's Avatar
i just got wheel rotation 1 month ago, was that the reason ?
i got an xle by the way lol
Old 10-07-2010, 12:41 AM   #8 (permalink)
could be casue of the rotation, maybe ur tires are worn, or u messed up ur allignment(i think thats a reason)
or idk toyotas are cheaper made cars, thats why corollas are about to burst into crap when u go more then 80
but u should check it out if ur cars newer
2.5
lookinn freshh
Old 10-07-2010, 12:44 AM   #9 (permalink)
um, things like this can happen if you go over a pothole or somethin on the road, I'd suggest getting the tires checked out at a tire shop..one of your tires must be off by 1/2- 3/4 lb (became unbalanced)
I think I paid like..15 bucks to get it checked out and fixed? well good luck
Old 10-07-2010, 12:48 AM   #10 (permalink)
xle's are chillin
the only possible solution now is to trade it in for an SE
ahah im joking
but u should get it checked it, if you dont and you keep going on with how it is...possibly in the long run it could mess up your axle adn u dont wanna go through all that trouble
2.5
lookinn freshh
Old 10-07-2010, 01:45 AM   #11 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Might be tire cupping.
Old 10-07-2010, 04:55 AM   #12 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
Can someone tell me about my problem plz ? It shaken like hell when speeding > 80 MPG, but quite like a mouse < 70 MPG.
is this the same car some one else was driving and destroyed it, and you had it fixed.........??
Axle oil leaking!
if so, then i'd suspect it wasn't fixed properly..........
then too, the speed limits ARE NOT 80 mph........!!!!!!
Glenn8963 is offline   Reply With Quote
Old 10-07-2010, 07:28 AM   #13 (permalink)
View Moutee's Photo Gallery
The usual suspect. Check this first before jumping to any other conclusions.
Moutee is offline   Reply With Quote
Old 10-07-2010, 04:01 PM   #14 (permalink)
Gameroom cash: $303755
This most likely a problem with tire/wheel balancing or the tires themselves have belts inside that may have shifted. When belts shift, it throws the balancing off. If the belts have shifted, the only cure is to get new tires.
You said you had the wheels rotated about a month ago. Were the tires/wheels rebalanced at that time? Was that when this problem started? If so, were the tires on the rear of the car there for some time; like 20,000 or 25,000 miles? If so, the tires that were in the rear and are now in the front, may be cupped as GT-R pointed out. With front wheel drive cars most of the weight is carried by the front tires. The rear tires don't carry much weight and as a result of that they can actually bounce a bit. If left on the rear for an extended period of time, that bouncing can actually cup the rear tires. You generally don't feel it as long as they are in the rear, but rotate those rear tires to the front and the cupping is noticable as vibration through the steering wheel. Again, the only cure is new tires.
Mike
Old 10-07-2010, 05:10 PM   #15 (permalink)
Mike
OP also drove the car through a rough patch on the highway and damaged several components under the car...maybe tires were damaged?
