2004 Camry A-Pillar or front pillar housing question? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2010, 03:50 PM   #1 (permalink)
View zachunderwood's Photo Gallery
I've got a 2004 Toyota Camry SE .... Just wondering if anyone has any experience trying to remove the A-Pillar (driver's side) or the driver's side front pillar?
I'd like to run a wire from my radio to the sun visor (bluetooth) and I'd like the wire to come through the A-pillar housing.
Any ideas folks? Thanks!
zachunderwood is offline   Reply With Quote
Old 10-07-2010, 03:55 PM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
Do you have curtain airbags?
2002 Camry SE V6 "Snow White"
Old 10-07-2010, 05:23 PM   #3 (permalink)
None
As far as I can tell, there are no side curtain air bags. I would think that I'd see a little area telling me that .. but I don't see that.
Old 10-07-2010, 09:15 PM   #4 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
if you had curtain airbags, there'd be a little square with SRS on the pillars.
if you don't have curtain airbags, just pull out on the trim starting from the top. Should pop out fairly easily (two clips). once the clips are popped out, pull it straight up, there's a little tab on the bottom that sticks into the dash.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 10-16-2010, 10:25 PM   #5 (permalink)
Thanks a bunch for replying to my post! Your advice was "spot on". I was able to pull the plastic covering away from the A-pillar drivers side with no problem whatsoever.
I now have a handomse Bluetooth microphone attached to my drivers side sun visor with the cable being hidden behind the a-pillar plastic housing. Thanks for all your help!
Old 01-27-2011, 01:07 PM   #6 (permalink)
View wallyballs's Photo Gallery
This was the same help I was looking for. Thanks!
wallyballs is offline   Reply With Quote
Tags
a-pillar, camry 2004, pillar
