Originally Posted by vvti-me
I would say try sanding down the brake pads.
I will add to sand a small 45 degree angle on the front edge of the pad.
Only do this after you have tried everything else. The noises usually come from other spots, but when you have covered everything else sometimes this angle on the front edge will reduce over all vibration on the pad.
By front edge, I mean the leading edge the rotor spins into when the car is in forward motion. One edge is leading and one edge is trailing. It won't hurt anything to put a small 45 degree angle on both edges.
