Strut replacement cost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2010, 09:44 PM   #1 (permalink)
View zedman280's Photo Gallery
Hi there, my mother in law was just quoted $ 1200.00 CAD to replace the rear struts (apparently one is leaking) on her 2002 Camry JXE. If she wanted to do the fronts as well it would be $ 1500.
That sounds ridiculously high priced. I have not looked into it yet, but are the struts that pricey ? I mean, it's an easy job, what gives ? are they trying to hose her ?
Just looking for an opinion.
cheers !
zedman280 is offline   Reply With Quote
Old 10-16-2010, 09:51 PM   #2 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
Replace all 4 struts & Springs - $280 USD labor
MJZ is offline   Reply With Quote
Old 10-17-2010, 12:27 AM   #3 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
yeah, here in NYC you can find any shop who can do this job fast and quick for a very low price. any experienced strut mechanic does this blindfolded having the right tools not more than 300 dollars labor.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 10-17-2010, 11:56 AM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Parts may be more expensive in Canada. In the US the rear struts are about $90 USD each plus shipping. The fronts are about $70 USD each. Therefore all four struts are about $320 USD+shipping.
The Monroes have a lifetime warranty and $50/axle credit to remove them if not satisfied with the ride ("Safe and Sound" guarantee in the US, not sure abut Canada). KYB does not warranty against normal wear. Monroe gives $50 axle to install/remove, so $100/axle may be more "reasonable".
Monroe 90-day Safe and Sound Guarantee:
http://www.monroe.com/support/warranty.asp
I'd recommend getting new struts mounts (front $50 USD each with new bearing, rear $38 USD each). The rears can usually be reused, but if the assemblies are taken apart, I'd change the rear mounts.
Get a four-wheel alignment after that for about $70 USD.
So in any case the shop is taking her for a ride.
For reference, check www.rockauto.com.
cheers !
Old 10-18-2010, 11:45 AM   #5 (permalink)
Thanks for all the replies and great info gents. It's most appreciated. I will be making some calls to see howmuch I can get the parts for locally, if it's quite high, I'll just order from rock auto and have shipped to the border !
Cheers and thanks again.
