2004 V6 Cold Idle High - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2010, 05:50 AM   #1 (permalink)
View Kim75's Photo Gallery
Thanks for taking a look at my problem.
I just purchased a V6 Alitise, 100,000k. When start it revs around 2000 for at least 3-5 mins, then it is fine and revs around 1000 I am sure this is not normal, and when I put it into gear it takes off. My brother a mechanic and thinks it may be the stepper motor sticking, which I have no idea how to locate! I have had the auto serviced and it is okay. What are your expert thoughts, I am not keen to take to a mechanic just yet
Kim75 is offline   Reply With Quote
Old 10-21-2010, 07:51 AM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Cheap things you can look at are:
-check vacuum hoses for any broken or leaking lines
-check air filter making sure it is clean
-disconnect the battery for a few minutes to reset the engine computer
gdanaher is offline   Reply With Quote
Old 10-23-2010, 01:37 PM   #3 (permalink)
View SimonRage's Photo Gallery
I would also guess EGR issues, but you don't have a check engine light on, right?
SimonRage is offline   Reply With Quote
Old 11-26-2010, 04:57 PM   #4 (permalink)
View jermag24's Photo Gallery
I also have this issue, mine only has 50k miles, can someone check what RPM their V6 Camry idles at when cold? I also don't have a check engine light, but I've never seen a fuel injected car idle this high when cold. Maybe a throttle position sensor?
jermag24 is offline   Reply With Quote
Old 11-26-2010, 07:36 PM   #5 (permalink)
View SlapHappy's Photo Gallery
My Camry also does this. I thought this was normal? Afterward it drives normal. If i let it warm up. If i don't it won't shift to 3rd until it hits like 5k rpm. But only when i do not let it warm up.
SlapHappy is offline   Reply With Quote
Old 11-27-2010, 02:52 PM   #6 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
when it's freezing cold out, i have a habit of letting my car warm up for 3-5 mins... i dont touch the accelerator and it's always 1500-1900ish for the first 30 seconds
Dave-o is offline   Reply With Quote
Old 11-27-2010, 07:26 PM   #7 (permalink)
It just seems to be too high, for too long. I mean, if you're not on the brakes it lunges forward when you put it in gear. Could be dangerous, it's at least annoying as hell.
