Rear wheel bearing carrier stuck in brake backing plate.. HELP
03 Camry - v6 - 170k miles
Last week: Worsening hum over the last 30k that originates from RR wheel. Stripped RR and could hear that the bearing was bad just spinning by hand. Probably would've locked up any day now. Ordered online.
Today: Stripped back down, removed the 4 bolts that held carrier/backing plate to spindle(?) and pulled, the carrier and the backplate came down, together. I soaked everything in PBlaster penetrating oil. Ive tried everything in mine and autozone's arsenal to get that sucker out, its in good. I tried a universal 2 jaw puller from the rear to pull the backing plate away while pressing the carrier out. I tried heating up the backing plate with a torch and pressing the carrier out. I tried heating up the carrier and pressing it out. I tried a slide hammer from the front. I even try the BFH (big f'ing hammer) and no luck. I'm guessing since the bearing was about shot, it was probably running rediculously hot and somehow fused itself into the backing plate.
HELP. Any other ideas? I'm trying to find how much a backing plate costs and see if that would just be easier at this point, I'm stumped at what else to do.
