Gen 5 2.4 Engine Oil After 100K Miles - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Which Oil is best for Gen 5 at 100K MIles?
Castrol Edge or GTX High Mileage 2 13.33%
Penzoil Platinum or High Mileage 3 20.00%
Mobil 1 High Mileage or Extended Performance 7 46.67%
Quaker State Ultimate Durability or Enhanced 0 0%
Valvoline MaxLife or Premium Conventional 5 33.33%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
Old 10-25-2010, 10:20 PM   #1 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
Gen5 Gen 5 2.4 Engine Oil After 100K Miles
Dear Gen 5 Troopers, after you hit the 100K milestone, what engine oil do you use? Think is the best to use? Conventional, Synthetic Blend, or Full Synthetic? And which Brand? To keep these powerhouse refuse to die engines running smooth for the next 100K miles:
How do you vote?
1. Castrol Edge
2. Penzoil Ultra
3. Mobil 1 Extended Perforamance
4. Quaker State Advanced Durability
5. Valvoline MaxLife
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 10-26-2010, 07:53 AM   #2 (permalink)
Gameroom cash: $195250
View ImJustMe55's Photo Gallery
Personally I use Amsoil on my car with 175,000 miles on it and I change my oil every 10k miles, but on my wifes car I use Mobil 1 Extended Performance. I've seen tests and the closest thing to Amsoil that you could buy off the shelf is Mobil 1 Extended Performance.
ImJustMe55 is offline   Reply With Quote
Old 10-26-2010, 03:49 PM   #3 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
Gen5
Thanks mate for your kind feedback. I have not done so yet, but I may try that Mobil 1 Extended Performance. I have been nervous to put full syn or syn blend in my engine after driving for over 100K miles strictly on toyota dealership dino conventional. by the way toyota oil, oem oil, is full dino right?
Old 10-26-2010, 03:54 PM   #4 (permalink)
You're welcome. I've been running fully synthetic since I had my car though. I'm not quite sure what you mean by dino, but as far as I know Toyota only uses Synthetic if you ask them to with the exception of the new ones that run that 0W20 oil.
Old 10-26-2010, 08:25 PM   #5 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
Dino is my slang for conventional non syn motor oil. i always thought that toyota been putting this in the gen 5 cars at the service centers.
Old 10-26-2010, 08:46 PM   #6 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
I am at around 120k miles and use normal Mobil 1 full synthetic 5w30 not highmileage.
2002 Camry SE V6 "Snow White"
Old 10-26-2010, 10:15 PM   #7 (permalink)
View FireLikeIYA's Photo Gallery
I personally run Mobil 1 full synthetic in all of my cars. It is the cheapest (Approx $4.50 qt if you buy at Costco with coupon) and probably the most accessible full synthetic. So far I have 179K on my camry and it runs fine. A bit of FYI when transitiong from a conventional oil to a full synthetic on a higher mileage vehicle... Synthetic will actually clean out the sludge buildup in your motor... this translates into a fair amount of black smoke coming out of your tailpipe when the car is under heavy load (like accelerating from a stop). I do not believe this is bad for your car just something to be aware of. I would recommend performing an engine flush before going to synthetic.
Oh yeah, I also go 7-8K miles between oil changes when using a full synthetic on my Camry.
FireLikeIYA is offline   Reply With Quote
Old 10-27-2010, 04:07 PM   #8 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
Thanks Brother.
Old 10-27-2010, 10:56 PM   #9 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
I have about 110K on my Camry and I still use 5W30 as well. I don't think that this mileage is high enough to warranty special blends yet - especially if you've been frequently changing your oil from day 1. I do mine every 5000km.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 10-28-2010, 09:39 AM   #10 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
Gen5
copy that mate, i have been doing oil changes every 5000 miles since 2005 with Toyota Genuine Motor Oil sold at the service center. but i am now going to break with that tradition, and so far no problems, so your statement sounds excellent, so, maybe i follow your thought on this one, or still consider to switch to full synthetic. however, what i really want is to keep that engine clean, no sludge, so maybe oil with detergents is the way to go, out of all the brands, find one that has the most detergents and additives that dont hurt the seals, etc.
Old 10-28-2010, 11:00 AM   #11 (permalink)
i use Zmax every so often.
Old 10-29-2010, 04:05 PM   #12 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
Additives are a farce.
Any full synthetic will serve you well.
deadrx7conv is offline   Reply With Quote
Old 10-31-2010, 09:19 PM   #13 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
Gen5
copy that sir. thanks.
Tags
castrol, mobil 1, penzoil, quaker state, valvoline
