2007 SE Sway Bar Bushings and Pins - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2010, 09:57 AM   #1 (permalink)
View muddyoutdoors's Photo Gallery
We are having a loud thump sound every time we hit a bump. We thought the rear drivers side shock may be bad. We carried it in and received a $680 quote to replace the rear sway bar bushings and pins. They said the shock was fine.
Is this something that I could do my self?
Thanks
muddyoutdoors is offline   Reply With Quote
Old 10-29-2010, 10:09 AM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Absolutely. This is not brain surgery work. It's possible that something has just come loose because that stuff shouldn't be worn out yet unless you drive on a test track for a living. Jack it up and block it so you don't get any surprises, then check the torque on the bolts and see if anything is loose. Spray some silicon lube and maybe some white grease on the joints and see if it cures the problem before spending any serious money.
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
muddyoutdoors (10-29-2010)
Old 10-29-2010, 10:18 AM   #3 (permalink)
lol, we don't drive on a test track. But we do have close to 95,000 miles on the car. Where is the best place to buy sway bar bushings and pins. The mechanic checked and said they were definitely worn out.
Old 10-29-2010, 10:34 AM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
if i were you i would just upgrade to the UR sway bar. Comes with new bushings. Im a 18 yearold kid and i did it in my driveway...Actually when i did mine i forgot to tighten one of the swaybar links to the sway bar itself and it made a clunking sound. Crawl under there and tighten everything first. But if i were you id get a UR bar and call it a day.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 10-29-2010, 10:41 AM   #5 (permalink)
How much is a UR Bar?
So are you saying that I may just need to tighten everything?
Old 10-29-2010, 10:45 AM   #6 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
i would check and see that everything is tight before i spend any kind of money. Check the brackets and make sure they're tight. Check the bushings, and also make sure the bar itself is tight on the sway bar links. WHat i did was had a friend jump on the back door frame to rebound the suspention to see exactly where the noise was coming from and i could actually see the swaybar link moving. A UR sway bar is only about 200 bucks and it comes with new bushings/brackets.
Old 10-29-2010, 11:47 AM   #7 (permalink)
Gameroom cash: $195250
View ImJustMe55's Photo Gallery
+1. Check the bushings and sway bar end links to make sure they are tight. If they are tight then check to see if the bushings are really worn. If they're not worn unbolt the sway bar end links and check to see how loosely they move at the joint (pretty much if you can move them with your pinky then they're bad). A good friend of mine, whose been a mechanic for as long as I've been living, told me that if I hear a noise from my rear end it would most likely be the end links. He said he's seen it happen to a lot of different vehicles. Like everyone else said the sway bars aren't hard to replace nor are the end links so you could easily do this yourself in your driveway or a parking lot.
ImJustMe55 is offline   Reply With Quote
Old 10-29-2010, 03:52 PM   #8 (permalink)
Maven
gdanaher's Avatar
To swap out the sway bar you need some space under you, on a lift in other words. It would be easier to replace the minor parts, and those are best found at the dealer or ordered from our good guys here on TN.
