07 heater problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2010, 08:30 AM   #1 (permalink)
View Chrisb_75's Photo Gallery
07 heater problems
I have an 07 2.4L camry and now that it's gotten cold out I started using the heater but it only
Blows heat out of the drivers side vents. It blows as hard on the other side it's just bone cold.
I'm not sure if it's an easy fix or not.. Any help would be great, thanks
Chrisb_75 is offline   Reply With Quote
Old 10-30-2010, 09:43 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3627950
Could be the heater core on the right side. There are vertical tubes that run across the heater core, and water enters from the side. As a mechanic buddy of mine described it once, over time the end tubes get bits of silicone rubber from the seals stuck in them plus regular corrosion buildup. It progressively blocks off each tube on the farthest end which is the passenger side and gradually works its way back across the heater core plugging up the tubes one at a time. You could try flushing the core or replacing it all together. If you haven't done so already you might try doing a search of this forum for other past threads on the subject.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 10-30-2010, 10:35 AM   #3 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Or a servo drive to door linkage is loose......
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
