02 Camry LE Programming Key - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2010, 03:02 AM   #1 (permalink)
View skyline101's Photo Gallery
I just bought a blank key for my 2002 Camry LE and I got it cut at my local hardware store. I tried to program my Key Transponder using directions from the internet and they didn't work.
Does anyone have the real directions?
Thanks
skyline101 is offline   Reply With Quote
Old 11-02-2010, 06:30 AM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
make sure you follow those instructions to the T. When it says 1 second, make sure you count out, "one mississippi" or else it wont work. It took me a couple of tries the first time I did it, but you will get it.
MrSo0h0o is offline   Reply With Quote
Old 11-02-2010, 10:18 AM   #3 (permalink)
DIrections
Here's my directions.
Please let me know if I am wrong
Add Key:
1. Press and release the brake and accelerator pedals
once, doing both at the same time.
2. Put the existing master key into the ignition.
3. Press and release the accelerator pedal five times
within 15 seconds.
4. Press and release the brake pedal six times within 20
seconds and remove key.
5. Insert new key into ignition within ten seconds.
6. Press and release the accelerator pedal once within
ten seconds.
7. The security light will turn off after 80 seconds.
This indicates that the new key is now registered.
8. Remove new key. Press and release the brake
pedal once.
Old 11-02-2010, 03:17 PM   #4 (permalink)
MrSo0h0o's Avatar
silly question.. are you sure you need a transponder key?
