It isn't really "hesitation".
On a pressure scale of 1-10, with 10 being your foot hitting the throttle to the ground as fast as possible, the computer simply does not want to go on a scale of 1 or 2.
This method of controlling throttle "uncertainty" is most certainly because of the demographics of Camry drivers.
If you want to get optimal response out of it, you have to drive it differently. Shift down into first gear, and you will NOT be able to go like you wanted without your tires spinning out.
You also can't expect it to respond to a "1" like a BMW would.
