CEL/MIL P0420 - way to test O2 sensor? - aftermarket cat?
So at 107k miles my 2.4L '03 CEL came on. Code read as P0420, "bank 1 catalyst efficiency below threshold". The light subsequently went out a few hundred miles later, came on and went off again. I assume it will be back soon.
So, I gather from reading that it's most likely a bad front cat (this is the one in the manifold, right?) and less likely to be the O2 sensor (which one?). A couple of questions: I have a multimeter and some ramps, is there a way to definitively see if it's the O2 sensor without replacing it? I've seen people mention this but without a specific DIY method. Are the aftermarket cats ok? Places like rockauto and authaus az have them for <$400. I can certainly install one myself, provided they are bolt-on and I don't have to do some special ECU reprogramming.
Thanks guys
2003 Camry XLE 2.4L
