FM reception - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2010, 03:50 AM   #1 (permalink)
KIKAI 08
wieyu's Avatar
View wieyu's Photo Gallery
FM reception
Can anyone know how could I boost the FM signal on my radio. It's been bad since I change my stock radio to Pioneer. All reply is appreciated, thanks.
wieyu is offline   Reply With Quote
Old 11-09-2010, 05:17 AM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Plug in the antenna amplifier.
Here is the location for the manuals:
camry^stuff^com
(remove the first, dot the second symbol)
It would help if you tell us the year and trim levels. The more info the better.
There may be a wire on the replacement head unit that has +12 volts on it when you turn on the radio, Just attach that to the wire to the antenna amplifier (I don't remember but it might be orange.)
Good luck......
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 11-09-2010, 05:19 AM   #3 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
have you tried tuning the new radio..?? usually on the back of the radio there is a very small screw you need to turn one way or another, and the radio is supposed to be set at a station high up the band (1400 and up). check the radio instruction sheet. as for FM boosters, i have never found any to be worth a crap.
Glenn8963 is offline   Reply With Quote
Old 11-09-2010, 05:42 AM   #4 (permalink)
KIKAI 08
wieyu's Avatar
I have a 2009 Toyota Camry SE. The Stock radio has to pins but Pioneer has only one input for antenna
Old 11-09-2010, 11:47 AM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
It's in one of the plugs..... When I have more time I will be able to help you.
MFG 02/25/2010
Stock, Shucks!
Old 11-09-2010, 04:42 PM   #6 (permalink)
Twin & (1 of 8)
Luna2's Avatar
It is the orange wire pin 8 in the 10 pin connector with the l & r front speakers and power.
MFG 02/25/2010
Stock, Shucks!
Old 11-09-2010, 05:15 PM   #7 (permalink)
KIKAI 08
wieyu's Avatar
Luna
Basically run a wire connecting from the orange wire from the ten-pin connector of the front speakers to 12 volt on head receiver?
Old 11-09-2010, 05:27 PM   #8 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Luna
There are 2 12 volt sources (1 for power, switched with the ignition switch) and (2 one with 12 volts all of the time for memory). connect to the switched power, otherwise you will put an unnecessary drain on the battery with the ignition off.
There may be a wire on the replacement head unit that has +12 volts on it when you turn on the radio, just attach that orange wire to the wire from the radio that has the switched 12 volts. If you have the make and model of the radio that you installed, I might be able to locate that wire color and location for you.
MFG 02/25/2010
Stock, Shucks!
Old 11-09-2010, 10:22 PM   #9 (permalink)
KIKAI 08
wieyu's Avatar
It is a Pioneer AVIC-X920BT
Thanks
Old 11-10-2010, 12:54 AM   #10 (permalink)
Twin & (1 of 8)
Luna2's Avatar
On page 11 of the installation manual:
Blue/White "wire"
To auto-antenna relay control terminal.
If the vehicle has a glass antenna, connect to the antenna
booster power control terminal
(max. 300 mA 12 V DC).
That wire from the glass antenna is orange on pin 8 of the connector.
Looking from the pin side of the connector in the vehicle harness, is:
10 9 8 7 6 5
4 3 blank 2 1
MFG 02/25/2010
Stock, Shucks!
