03 Camry XLE 4Cylinder - Slight wobble at low idle speeds
I have replace all 4 struts/strut mounts/sway bars and also rotors (wagners) and brake pads.
I still get a vibration when I am at higher speeds but I was told it was most likely the tires. (have replaced them yet)
Then I noticed that when I am coasting at idle speeds (5mph or so) that the car seems to slightly 'wobble' from side to side.
Any idea on what this could be a symptom of? Could this also be what is causing the car to vibrate at higher speeds? Could the tires cause it?
