2002 Camry Test Drive - Shaking
Test drove a Camry with over 170,000 miles. The car is perfect other than a slight engine shake (more like a quiver) when stopped at a red light with the clutch depressed. The a/c was on, and i was trying to tell if the shaking coincided with the compressor kicking in. When taking off from the red light, if given some gas, it takes off without any shaking. but if you give it barely any gas, it shakes a little more than I would suspect is normal until its fully engaged in the gear.
The only other issue was the clutch itself. I have never driven a manual camry, but all other manuals I have driven have a lot of travel while depressing and you can typically "feel" when the clutch begins to engage. On this car, the clutch engages as soon as you start to depress the pedal, and has a relatively firm feel and short travel. Is this normal? I really appreciate any advice. Thanks!
