Camry wouldn't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2010, 08:18 PM   #1 (permalink)
View bdsheth's Photo Gallery
Hey guys, I recently got a camry 2002 LE, it's my first car so i don't know much about cars and how to fix them.
But today right after i got home from work. i parked it for 10 minutes and tried to start it again but it wouldn't start. I didn't get any noise when turned the ignition. I tried jumper cables from another car, that didn't work either. My uncle got me to push the car in neutral and while i was pushing it he switched into park and it stopped with a jerk. Then turned the key and it just started up. Tried it after that about 4 times and it started up properly.
I don't know if i should have it checked out. I don't even understand whats wrong with it. Any advice?
Thanks in advance.
bdsheth is offline   Reply With Quote
Old 11-12-2010, 12:26 AM   #2 (permalink)
-Kenny-
Guest
Posts: n/a
View -Kenny-'s Photo Gallery
if the car didnt make any noise when u the ignition then it has to be the starter. happened the same with my buddy S14. it started again bc something it would work again once u hit the start( which the jerk help). this is a common thing for old car
so next time it happen again, then its time for a new starter
Old 11-12-2010, 07:53 AM   #3 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
Suggest test the trigger wire going to the starter. Simple test to cross-out the uncertainty.
If you're not getting 12v+ to the wire w/ rectangular plug, check the ignition to see if it even send power.
If you're not getting anything at he ignition, check your neutral safety switch (NSS).
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 11-14-2010, 04:43 PM   #4 (permalink)
thanks a lot for your input guys. I've determined the problem to be the starter. because when i tap at it with something the car starts up....So I'm guessing it's the starter itself.
I was wondering if anyone knew where to get a '02 Camry starter in canada? what would be a good place to visit if i was looking to save a bit of money?
Thanks a lot in advance
Old 11-14-2010, 07:48 PM   #5 (permalink)
View joshuaboston's Photo Gallery
Where in Canadia? But ebay USA look for your starter and see it they ship to Canadia.
joshuaboston is offline   Reply With Quote
Old 11-14-2010, 08:59 PM   #6 (permalink)
Either, toronto, guelph or waterloo/kitchener
Old 11-14-2010, 09:02 PM   #7 (permalink)
have you been to lulu's? longest bar in the world.
Old 11-15-2010, 04:49 PM   #8 (permalink)
nope...O_O whats that?
