Need ignition sys illustration:2007 camry V6 rough idle and vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2010, 08:25 AM   #1 (permalink)
View jbbnet's Photo Gallery
I had an issue with my v6 camry 2grfe. The other day it had a rough idle and little engine power. Blinking check engine light was codes P0300 P0303, multiple misfires and misfire cyl #3, tried to figure out which coil was bad and swapped the coils around (far left one to the far right one, leaving center coil in place) and the code changed to P0300 p0304 p0306. Swapped them back to the original position and then only got P0300. I had the rotten egg smell from the catylic converter. Today I replaced all three coils and it drives much better but there is a small engine knock, like detonation. I wasn't sure if the CAT converter was clogged now or what else to check. Front spark plugs appear fine but I couldn't check the rear plugs.
Any common issues or ideas I should look into?
How do you access the rear plugs?
Does anyone have ALLDATA diagrams/illustrations of the ignition system?
Thanks,
2010 VW Jetta TDI
2008 M5 w/SMG Space Grey on Black, Breyton GTS 19's
2007 Camry SE V6 Black on Black
1998 Lexus GS400 Spectra Mica, SSR staggered 19's, Apexi World Sport Series exhaust, TRD Suspension, L-Sportline 1.75"
1997 Tacoma LX
jbbnet is offline   Reply With Quote
Old 11-12-2010, 04:15 PM   #2 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
how many miles on your car?
Makes me wonder when my 2GR will start acting up.
MJZ is offline   Reply With Quote
Old 11-12-2010, 08:04 PM   #3 (permalink)
Almost 80k. First issue ever.
2010 VW Jetta TDI
1997 Tacoma LX
Old 11-14-2010, 08:26 PM   #4 (permalink)
I found it, http://www.cars4qatar.com/cars4qatar...E_Ignition.pdf
2010 VW Jetta TDI
1997 Tacoma LX
The Following User Says Thank You to jbbnet For This Useful Post:
ahampton2k (11-15-2010)
