Blue Smoke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2010, 06:51 PM   #1 (permalink)
View RonInPA's Photo Gallery
Exclamation Blue Smoke
2007 Camry XLE 3.5
My baby is puking out blue smoke. This happened over night no warning at all. Its real bad in the morning and also while idling at a red light. There is not much info on the newer Gens with high miles. The only thing I ever had to replace where brakes, tires oil changes and the Battery. I have 145k mostly highway miles. I have read here and there could be emission stuffs? Never had any codes either. Anyone have any ideas? I'm hoping its not the valve seals.
Thx
RonInPA is offline   Reply With Quote
Old 11-12-2010, 07:26 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Most oil consumption problems are old valve stem seals.
You can also do a compression check to evaluate the general condition of the rings, but it only tells you the compression rings. The oil control rings may be gummed up but a compression check won't tell you directly. It's only an indirect way to see what shape the oil rings may be in.
You might want to try a High Mileage oil and see how it may help, before going to a heavier viscosity. What weight of oil do you use? And the oil change interval? The 3.5L's filter is so small it's a joke.
Originally Posted by RonInPA View Post
2007 Camry XLE 3.5
Thx
Old 11-12-2010, 07:54 PM   #3 (permalink)
View greycamRy's Photo Gallery
I would also try running seafoam through your engine. Cleans it out real nice, gets out any carbon deposits and gunk. Get it from your local auto/hardware store.
2007 Magnetic Gray Toyota Camry LE
BOMZ Racing SRI/6000k HID low beam/20% tint all around/Smoked LED Tail lights/Blue LED Interior Lights/Verde Designs Black 17" Rims
greycamRy is offline   Reply With Quote
Old 11-13-2010, 12:31 AM   #4 (permalink)
trdcamry1211's Avatar
View trdcamry1211's Photo Gallery
blue smoke is oil burning off....most likely a leaky seal...might wanna inspect your spark plugs for oil
2007 SE V6
6 speed auto
stock remote start
jbl
6000k 55 watt ddm hid kit
trdcamry1211 is offline   Reply With Quote
Old 11-13-2010, 02:35 AM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
PCV stopped up.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 11-13-2010, 12:06 PM   #6 (permalink)
TN's Resident Goddess.
Lauren's Avatar
Gameroom cash: $549822
View Lauren's Photo Gallery
Most likely. Especially if you live in a climate where the temperatures fluctuate. Hot, then cold will cause the seals to dry out and crack so they don't 'seal' as good as they once did.
I am the kind of woman that when
my feet hit the floor each
morning the Devil says,
"Oh shit, She's Up!"
http://www.cardomain.com/ride/3389758
Lauren is offline   Reply With Quote
Old 11-13-2010, 12:12 PM   #7 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
Im going with bad valve seals, especailly given the fact that you're right at the miles they start breaking down. At about 100 - 150K or so. Not the end of the world, but I wouldn't let it go for to long.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 11-13-2010, 03:10 PM   #8 (permalink)
Papa
View Roger R.'s Photo Gallery
You say it happened all of a sudden. I find it difficult to believe that valve seals, gummed up rings, or even a stopped up PCV valve would cause a SUDDEN smoking problem. Have you by chance pulled up to a diesel pump by mistake and pumped some diesel in the tank.
Don't get me wrong, it could be any or all of the above, but happening overnight sure throws a red flag up to me. Think about what you've done just before it happened. Good luck and let us all know what you find.
Roger R. is offline   Reply With Quote
Old 11-13-2010, 03:19 PM   #9 (permalink)
Hello, Good Morning
ItsMeJon's Avatar
View ItsMeJon's Photo Gallery
I'd be careful with the sea foam option. I know a guy who sea foamed three of his cars each one the head cracked.
ItsMeJon is offline   Reply With Quote
Old 11-13-2010, 04:54 PM   #10 (permalink)
Lauren's Avatar
Could be that if the OP is in a colder climate, he's now noticing the smoke due to the cold weather... or just happened to notice it since it is coming out of the rear of the car. It could have been going on for a few weeks and he just happened to look up at the right time.
I thought diesel pumps had a specific type nozzle that prevented it from being put into a gas tank to avoid just that issue.
Old 11-14-2010, 08:46 AM   #11 (permalink)
Question Wierd
Last Weds I did use the seafoam (1/3 can), drive it about 80 miles and changed the oil. It smoked for two more days (Not a little but alot so I doubt it was still burning off but ya never know) and Sat Morning poof it stopped. Now Sunday and no evidence it had ever smoked. I don't believe this has a PCV valve at least they are not calling it that. Maybe something to do with the weather causing a part to fall? 70f during the day and 29f at nite.
I still think maybe an emission problem. I drive this car alot and I would have noticed it creeping up.
Thx for all your replies,
