Alrighty I'm new here and I've never really done anything with my mom's Camry but the other day I changed the oil and noticed while I was down there that it looks like the car has a transmission drain plug. The plug I am talking about is on the drivers side and the engine oil one is on the passenger side.
Is that correct? Its a 2004 XLE 3.3 V6. If someone has a picture of it to confirm that'd be great!
I'm not doing this stuff to her car as it only has 17,500 miles or so.
My cousin has a 2005 ES330 with 100k and wants me to do random stuff for him.
Since they are the same engine it's all good right?
Now onto spark plugs for the ES330. I've searched and read stuff about the rear 3 plugs being hard to get to. Is it really bad or around like 1 hour or so for all 3? Do I need to remove the wiper cowl stuff or is it all accessible as is?
There is also a knocking noise and feel in the steering wheel if it is turned left and right repeatedly. I've changed the swaybar end links to new MOOGs and that made it go away for a bit but now its back but not as bad. Any ideas on what this is? I've grabbed the shaft above the brake pedal closest to the firewall and applied downwards pressure on it while I jiggled the steering wheel. This seemed to dampen the noise a bunch.
edit- ^ his car has all original equipment on it. Nothings ever been swapped out other than the endlinks
Thanks guys!
