How Do You Change Antifreeze Nowadays? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2010, 08:24 PM   #1 (permalink)
View i_am_jim's Photo Gallery
Question How Do You Change Antifreeze Nowadays?
In the past when I changed antifreeze I drained what I could from the radiator drain, refilled with distilled water, ran the engine for a little, drained again. Then if I was going to flush I would add the flush and fill with distilled water. Run it 'til hot and for maybe ten minutes more. Then drain and flush two or three more times (depending on how much I was able to drain out). Add full concentration antifreeze for half the capacity of the system and add water 'til full.
But, nowadays the antifreeze is 50-50 mix. Any water you can't drain out will dilute this mix and I don't see any way to overcome that.
How do others deal with this? If you say you can drain all the water out, I have never been able to do that. There are always places in the engine where water gets trapped.
Two Camrys. '94 6cyl & '04 4cyl
i_am_jim is offline   Reply With Quote
Old 11-22-2010, 05:52 AM   #2 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
if not done correctly there will be air trapped in the cooling system creating a heck of a time to get rid of it, which CAN CAUSE the engine to over heat and do a whole lot of damage like warping the cylinder head, creating even MORE money to be spent.... just take it to a garage and PAY for a flush and refill. everything should be there, cleaning chemicals, additives, antifreeze, and WATER. in a matter of less than 1 hour, the car is done and good for another 2 years or more, depending on the brand/type of anti freeze used.
Glenn8963 is offline   Reply With Quote
Old 11-22-2010, 01:35 PM   #3 (permalink)
Tek-nique's Avatar
View Tek-nique's Photo Gallery
So, it's your opinion an individual cannot change their own antifreeze?
Tek-nique is offline   Reply With Quote
Old 11-22-2010, 05:10 PM   #4 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Let's be civilize and stay focus on the topic.
Thank you.
Old 11-22-2010, 06:55 PM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Guys. Keep this on topic and be nice. Violations ARE being given out. Thanks!
'07 Honda Ruckus Big Bore
Old 11-22-2010, 07:36 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
That's one thing I don't like about pre-mixed antifreeze. You're supposed to use the expensive antifreeze to "flush".
Try to find Peak Global concentrated at NAPA. It's a non-2EHA (a plasticizer) formulation. Maybe they can special order?
Both Valvoline Asian Vehicles and Peak Global now are 50%-50% too.
Old 11-22-2010, 07:39 PM   #7 (permalink)
Here is the Valvoline one:
http://www.valvoline.com/products/br...antifreeze/105
And the Peak concentrate:
http://www.peakauto.com/antifreeze-p...lifetime.shtml
Old 11-22-2010, 08:02 PM   #8 (permalink)
Freakin Scooters
I don't to de-rail this thread, but what's the deal with the Peak stuff. FULL system flush just to run it?
Old 11-23-2010, 12:28 AM   #9 (permalink)
Most (including dealers) just do a drain/refill these days, but some actually run clean water through the system.
In the latter case, full strength antifreeze is needed to reach 50%-50% concentration, because there is water in the block. When using pre-diluted it takes too much antifreeze (and $$$) to reach 50%-50%.
And the only long life, non-2EHA, full-strength antifreeze these days is the Peak Global. And I don't think you can even find this anymore. No, I won't use 2EHA antifreeze in systems not designed for it (like that Prestone All-Makes stuff).
Old 11-23-2010, 07:14 PM   #10 (permalink)
View JoeShmoe23's Photo Gallery
Originally Posted by JohnGD View Post
I like the Valvoline one.
JoeShmoe23 is offline   Reply With Quote
Old 11-24-2010, 05:27 PM   #11 (permalink)
View Mike Murrell's Photo Gallery
Trapped air issue easily remedied.
After draining and whatever else you like to do - refill radiator and overflow tank.
Leave radiator cap off. Fit a thick sock over the radiator spout. Don't stuff the sock into the radiator - fit the open end of sock over the top of the radiator spout where the cap attaches to like you'd fit a skull cap on top of your head. Start motor and turn on heater.
Let car idle for 15 - 20 mins.
You'll likely notice at this point that the air temp coming out of heater is not hot - that's the trapped air thing.
Stomp on the gas pedal - you don't have to go crazy - but give it a good blip. Wait a few secs for things to recover - then do again 2 or 3 more times - waiting a bit between each throttle blip. Afterwards - you should feel warm air coming out of the heater.
You're using the water pump to push coolant thru the system and air out the top of the opened radiator. The sock keeps the surge of coolant from getting all over other things.
This is far less messy than the Prestone gadget that fits into the top of the radiator to direct coolant flow outward. More often than not, this thing doesn't fit the radiator anyway and if it does - you still end up with a mess.
Sounds "hill-billy" but it's served me well for many years.
No trapped air problems.
Mike Murrell is offline   Reply With Quote
The Following User Says Thank You to Mike Murrell For This Useful Post:
LynchburgCSI (11-25-2010)
