Steering wheel vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2010, 07:14 PM   #1 (permalink)
View mbcamry09's Photo Gallery
Just noticed a slight vibration in the steering wheel at about 70mph. Nothing major, more just annoying than anything. Got the tires balanced today, vibration is still there. Car has never been wrecked. Any suggestions?
mbcamry09 is offline   Reply With Quote
Old 12-01-2010, 07:27 PM   #2 (permalink)
ilikecamrys
Cking's Avatar
Gameroom cash: $532185
iTrader Score: 17 reviews
View Cking's Photo Gallery
The brakes can be warped or u need an alignment,
2k8 V6 Camry SE\\55w6000kHID||3000kfogs||Work Emotion CR-ULTIMATES
||BuddyClub Coilovers||SPC Camber Bolts||TRD Dual Catback Exhaust
||Megan FrontTowerStrutBar||StopTech Slotted Rotors||PosiQuiet Pads
||Fujita ColdAirIntake||My thread!||TN lanyards!||
Cking is online now   Reply With Quote
Old 12-01-2010, 07:33 PM   #3 (permalink)
I will have that checked out also. It doesn't pull to either side. That is why I didn't just have it aligned today.
Old 12-01-2010, 10:14 PM   #4 (permalink)
'11 Camry SE
exclusive's Avatar
Gameroom cash: $305680
View exclusive's Photo Gallery
No way it's the brakes. That will happen when you are braking, not driving.
Main reasons:
Wheels unbalanced (not you)
Uneven tread wear (try swapping the rear wheels to the front)
Axles (look for a torn CV boot)
2011 Camry SE
|| Click my car below to see my thread ||
exclusive is offline   Reply With Quote
The Following User Says Thank You to exclusive For This Useful Post:
AlmightyCamry777 (12-03-2010)
Old 12-02-2010, 06:05 AM   #5 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
1) a broken steel belt or cord
2) a separated belt
3) a bent wheel
4) a missing axle shaft balance weight
5) a strut that is weakening
6) a wheel that was put on the car (as in tire rotation) and the rust around the hub was not removed, making the wheel to NOT sit flush on the hub, and torqued down unevenly.
7) too many stones (no matter how small) embedded into the tire threads, to throw off the balance. these should always be removed BEFORE a re-balancing.
8) slightly bent axle shaft
9) inner or outer CV joint.
10) inner or outer tie rod ends.
11) rack and pinion assembly.
Glenn8963 is offline   Reply With Quote
Old 12-02-2010, 07:00 AM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Also too much play in the wheel bearing.
gdanaher is offline   Reply With Quote
Old 12-03-2010, 07:44 AM   #7 (permalink)
Gameroom cash: $181400
View Paul3637's Photo Gallery
Had the same problem ..... multiple causes; link to my solutions
I posted a similar problem which turned out to have three separate causes and I just posted the resolution to the problem this morning at
http://www.toyotanation.com/forum/sh...98#post3403198
In my case, the tires were out of balance, the brake pads were defective and replaced at no charge under warranty, and one tire was defective.
Paul3637 is offline   Reply With Quote
Old 12-03-2010, 08:10 AM   #8 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
You probably have defective tires (one or more). You can rebalance a defective tire all you want but it's impossible to ever completely balance it. It's happened to me in the past.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 12-03-2010, 12:36 PM   #9 (permalink)
View pRzNiMaN's Photo Gallery
i have an 11 se and it has the same problem
but mines cause ive already messed up my tires and i need new ones like the tread is so uneven or worn that it makes it shake but less thatn 80 im fine
and i need balancing i beleive
the sad part is i only have 10k miles and my tires are gone
but then again my cars only 5 months old and it has twice the mileage it should
2011 camry SE (white)
2.5
lookinn freshh
Last edited by MR2Jedi; 12-05-2010 at 05:04 PM. Reason: Removed reported offensive language
pRzNiMaN is offline   Reply With Quote
Old 12-04-2010, 06:31 AM   #10 (permalink)
Cruisin' along
Glenn8963's Avatar
but mines cause ive already messed tires and i need new ones like the tread is so uneven or worn that it makes it shake but less thatn 80 im fine
yeah that's too bad. they put name brand tires on all new cars, but i do believe they are on the "lower end" of the price range.
any factory tire should last (at a minimum) of at least 50,000 miles, with proper tire inflation and regular rotations. i always got that many miles.
Last edited by MR2Jedi; 12-05-2010 at 05:05 PM. Reason: removed reported offensive language from quote
