??How do I Add Transmission Fluid To a 2007 Camry V6 SE (Six Speed Auto)??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2010, 11:01 PM   #1 (permalink)
chiprock's Avatar
View chiprock's Photo Gallery
All, I am wondering if anyone knows how to add transmission fluid to a 2007 Camry SE with the V6 and 6 Speed Auto Transmission. Apparently this is a closed system and requires very little maintenance. If you want to know how I got here...
The right transaxle failed and the Toyota dealership wanted $600 for just the part to replace. $400 more in labor. I couldn't find anyone that manufactured this part 2nd, 3rd party. I think it is because it is newer and is a less common engine. Everyone had the axle for the 4 cylinder. Anywas I found that Oreilly auto would refurbish my existing axle and give me 3 year warranty for $70! So I pulled it out and mailed it off. Took a little over two weeks (car was on jacks in the garage). During this time the camry leak almost exactly a quart (captured and measured). Now I put the axle back in and want to add this quart back (new stuff of course). But can't find where the heck to do it. I found one post that said it is behind the left splash shield but I was unable to locate... help anyone?
Thanks in advance,
Chiprock.
Note - If anyone needs help replacing that transaxle, let me know it has some particulars...
Last edited by chiprock; 12-03-2010 at 11:09 PM. Reason: posing it as a question not a statement in title
chiprock is offline   Reply With Quote
Old 12-04-2010, 06:48 AM   #2 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
i ain't never found any way to add fluid myself. not that i need to any how, but for "knowing sake"......
i gotta think many here will just say go to the dealer...
and if nothing else, at least now your posting got 'bumped up".
Glenn8963 is offline   Reply With Quote
The Following User Says Thank You to Glenn8963 For This Useful Post:
chiprock (12-04-2010)
Old 12-04-2010, 07:54 AM   #3 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
You need to read the service manual section on this topic. It is complicated, requires the fluid temperature to be at a specific point, etc. Ultimately the dealer will get their spiff whether you intended for it or not. There are two plugs on the side of the transmission case. You remove both of them add add to the top plug until it runs out the bottom plug, but again, fluid is expandable and if it is cold you will then have too much.
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
Old 12-04-2010, 07:55 AM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Follow the TSB step by step instructions.
Old 12-04-2010, 08:39 AM   #5 (permalink)
View Axxis8203's Photo Gallery
procedure is not that complicated at all IMO. did a drain and fill a few weeks back.
If you were able to remove the axle you are more than capable of performing this simple drain and fill.
PM me and i can get you linked to the Factory Service Manual Procedure.
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
The Following User Says Thank You to Axxis8203 For This Useful Post:
Old 12-04-2010, 08:52 AM   #6 (permalink)
chiprock's Avatar
Glenn8963 thanks for the bump,
gdanaher, I am thinking that since I know almost exactly how much I took out I can add without really having to go thru the whole process of checking, however... if I am doing it anyways may as do it the right way...
Another thing to note is the car is at 105,000 miles and I believe this is part of the regular service. Thoughts of bringing it to the dealership are starting to go thru my head...
njerald, you know where I could find this TSB?
Axxis8203, I pm'ed you. That would be really helpful.
Old 12-04-2010, 04:13 PM   #7 (permalink)
'07 XLE
Gen6
TSB REVISION NOTICE:
October 26, 2007: 2008 model year Avalon has been added to Applicable Vehicles.
Previous versions of this TSB should be discarded.
TSB UPDATE NOTICE:
The information contained in this TSB supersedes TSB No. TC011–06.
TSB No. TC011–06 is now obsolete and should be discarded.
This bulletin provides information on the proper automatic transaxle fluid fill and level
check procedures for 2007 – 2008 model year Camry V6 and 2008 model year Avalon
vehicles. Use the procedure below when checking automatic transaxle fluid level.
HINT:
For additional information including animations and video illustrations, please see the
Technical Training course E076: “Toyota ATF Level Inspection”.
NOTE:
Failure to properly adjust transaxle fluid can cause transaxle shifting issues or
damage to the automatic transaxle.
This procedure requires an additional 200 ml of ATF WS be added through the refill
hole AFTER the overflow plug has been reinstalled in step 7.
2007 – 2008 model year Camry (V6) vehicles equipped with the 2GR–FE engine
and
6–speed automatic transaxle.
2008 model year Avalon vehicles equipped with the 2GR–FE engine and 6–speed
automatic transaxle
PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME QTY
00289–ATFWS Same ATF WS As Needed
OP CODE DESCRIPTION TIME OFP T1 T2
N/A Not Applicable to Warranty – – – –
TRANSMISSION & CLUTCH
Introduction
Applicable
Vehicles
Parts
Information
Warranty
Information
TRANSAXLE FLUID LEVEL
– TC014-07 Revised August 11, 2007
Page 2 of 5
REQUIRED EQUIPMENT SUPPLIER PART NUMBER QTY
TIS Techstream*
NOTE: Software version 2.11.004
or later is required.
ADE TSPKG1 1
* Essential SST.
NOTE:
Additional Techstream units may be ordered by calling Approved Dealer Equipment
(ADE) at 1–800–368–6787.
SPECIAL SERVICE TOOLS (SSTs) PART NUMBER QTY DRW**
Transmission Fill System*
NOTE:
All components from this kit/set are required.
00002–11100–02 1 –
* Essential SST.
** Drawer number in SST Storage System.
NOTE:
Additional SSTs may be ordered by calling SPX/OTC at 1-800-933-8335.
1. Check the ATF temperature.
A. Turn the ignition switch ON, engine OFF.
B. Using TIS Techstream, check the ATF temperature with the following menus:
ECT / Data List / AT Oil Temp 1.
NOTE:
Check that electrical systems such as the air conditioning system, audio system, and
lighting system are OFF.
If the fluid temperature is between 104 – 113°F (40 – 45°C), proceed to
step 2.
Recommended ATF temperature: 104
°F (40°C) or less
If the fluid temperature is ABOVE 113°F (45°C), see Note below.
NOTE:
If the fluid temperature is 113
°F (45°C) or MORE, turn the ignition switch OFF and wait
until the fluid temperature drops below 104
°F (40°C).
Required
Tools &
Equipment
Inspection
Procedure
Page 3 of 5
2. Connect the Transmission Fill System.
A. Remove the refill plug.
B. Attach the quick disconnect
transmission fill adapter to the
refill hole.
C. Confirm there is at LEAST 2 liters
of ATF WS in the reservoir.
3. Activate the fluid temperature detection mode.
A. Using TIS Techstream, perform TC and TE1 Active Test with the following menus:
ECT / Active Test / Connect TC & TE1.
Use the arrows to turn TC and TE1 Active Test ON.
NOTE:
The TC to TE1 Active Test can also be performed using the Diagnosis Check Wire
(SST P/N 09843–18040) or equivalent. Active Test ON connects terminals TC and TE1,
Active Test OFF disconnects terminals TC and TE1.
B. Depress and hold down the brake pedal.
C. Start the engine.
D. Slowly move the shift lever from “P” to “R” to “N” to “D,” then back to “P,” allowing
each gear to fully engage prior to moving to the next gear position.
E. While observing the “D” shift
indicator on the combination
meter, move the shift lever back
and forth between “N” and “D” at
an interval of 1.5 seconds, for
6 seconds or more.
Inspection
Procedure
(Continued)
Transmission Fill Adapter Connected to
Refill Hole
Page 4 of 5
F. Confirm that the “D” shift indicator comes on for 2 seconds when in the
“N” position.
G. Move the shift lever from “N” to “P”.
H. Release the brake pedal.
I. On TIS Techstream, press the arrow button to turn TC and TE1 Active Test OFF.
NOTE:
Be sure to turn terminals TC and TE1 OFF. If the terminals are ON, the fluid level
CANNOT be precisely adjusted due to fluctuations in idle speed.
HINT:
Turning terminals TC and TE1 OFF activates the engine idle speed control mode.
Even after terminals TC and TE1 are turned OFF, the fluid temperature detection
mode is active until the ignition switch is turned OFF.
4. Warm up the ATF to fluid check temperature.
With the engine idling in Park, allow the transmission to reach the fluid check
temperature of 104 to 113
°F (40 to 45°C).
BELOW FLUID CHECK
TEMPERATURE
FLUID CHECK TEMPERATURE
ABOVE FLUID CHECK
TEMPERATURE
104
°F or less
(40
°C or less)
104 to 113
°F
(40 to 45
°C)
113
°F or more
(45
°C or more)
NOTE:
If the fluid temperature is within the fluid check temperature range, immediately
proceed to step 5, “Check the ATF fluid level”.
If the fluid temperature is 113°F (45°C) or more, turn OFF the engine and wait until
the fluid temperature drops to 104
°F (40°C) or less, and then perform steps 2 and 3
again from the beginning.
HINT:
In the fluid temperature detection mode, the “D” shift indicator comes ON, goes OFF,
or blinks depending on the fluid temperature.
BELOW FLUID CHECK
TEMPERATURE
ABOVE FLUID CHECK
TEMPERATURE
104
°F or less
(40
°C or less)
104 to 113
°F
(40 to 45
°C)
113
°F or more
(45
°C or more)
OFF ON Blinks
Inspection
Procedure
(Continued)
Page 5 of 5
5. Check the ATF fluid level.
NOTE:
The fluid temperature MUST be between 104 and 113
°F (40 and 45°C) to accurately
check the fluid level.
A. Remove the overflow plug with
the engine idling (A/C OFF).
HINT:
Removing the overflow plug before
reaching fluid check temperature
makes it easier to confirm when fluid
starts coming out at a steady rate.
B. Check that the fluid comes out of the overflow tube.
If fluid does NOT come out, proceed to step 6, “Refill the transaxle’’.
If fluid comes out, wait until the overflow slows to a trickle and proceed to
step 7, “Complete the transaxle fluid level Inspection Procedure’’.
6. Refill the transaxle.
A. Remove the overflow plug and gasket.
B. Connect the transmission fill system pump and hose to the quick disconnect
adapter already connected to the refill hole.
C. Add ATF into the refill hole until ATF flows from the overflow tube.
D. Wait until the overflow slows to a trickle and proceed to the
“Complete the transaxle fluid level Inspection Procedure’’ procedure in step 7.
7. Complete the transaxle fluid level Inspection Procedure.
A. Install the overflow plug with a NEW gasket.
B. Add an
additional 200 ml of ATF WS through the refill hole.
C. Stop the engine.
D. Install the refill plug with a NEW gasket.
Inspection
Procedure
(Continued)
Specified A/T
Fluid Level
Overflow
Tube
Tags
2007 transmission v6
