2003 camry exhaust issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2010, 12:31 PM   #1 (permalink)
View kevintomb's Photo Gallery
What is the diameter, outside I guess of the 2003 camry exhaust? I need to replace the flex pipe and its snowy here so I cant measure it. I found several on E-bay but dont know for sure the size.
kevintomb is offline   Reply With Quote
Old 12-07-2010, 12:36 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
I think it is 2.25 inches, but buy the part from Toyota and there will be no guesswork and you know it will fit. No brainer if it is snowing.
gdanaher is offline   Reply With Quote
Old 12-08-2010, 09:38 AM   #3 (permalink)
Thats not an option, as toyota wont sell just the flex part, but the entire front pipe, with an attatched cat, and all that stuff thats not needed. I found the Flex part ONLY on ebay for under $25.00 it simply needs the bad one cut out and the new one welded in place of it.
Old 12-08-2010, 05:03 PM   #4 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
Just take it to a local exhaust fabrication shop (not Meineke or Midas preferably), they will have a selection of flex pipe. Some front pipes are double walled which presents a challenge to the do it yourselfer when the flex section is cut out. If the area between the double walled pipes is not filled with weld, the exhaust may create a nasty whistle and a definite flow restriction. This job, correctly done, normally costs $100-150 depending on shop rates which is a lot cheaper than a stock replacement.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
