Replace cat? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2010, 01:12 PM   #1 (permalink)
View biggdave92's Photo Gallery
Replace cat?
My sister in laws 06 2.4l solara has a sound coming from the exhaust/cat area. she had a mechanic replace the gasket and it still makes the sound. I think the cat needs to be replaced. the car has 95k on it. Any advice? What is the cheapest way to replace this thing? Thanks for any help!
biggdave92 is offline   Reply With Quote
Old 12-07-2010, 01:23 PM   #2 (permalink)
I Eat Accords! W_(^_^)_W
my.rims.are.stock's Avatar
Gameroom cash: $114800
View my.rims.are.stock's Photo Gallery
What is the sound? Like a crackling or debris inside the exhaust/cat? Does the cat look damaged underneath?
my.rims.are.stock is offline   Reply With Quote
Old 12-07-2010, 01:30 PM   #3 (permalink)
na, its more like a "whooooooeeeeee" kinda noise. it speeds up and down with the engine rev. like its stopped up or somethin.
Old 12-07-2010, 01:50 PM   #4 (permalink)
So you are saying it sounds more muffled than normal? Do you see any scratches or anything on the cat itself? If you truely believe it is the cat then take it back to the mechanic and get him to check it. He can do this fairly easily because I believe the Solara's cat is just bolted into place. He can remove the cat and put in a test pipe. Does the car experience a decrease in performance (Does it not reach high RPMs or seem very sluggish when you drive it)? Does the engine die after after a period of time from running it?
Old 12-07-2010, 03:18 PM   #5 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
just remove the muffler. if the noise is still there like a "stuffed up noise" then its the cat. if the noise went away when you removed the muffler...??? it was the muffler that is bad. (plugged up).
Glenn8963 is offline   Reply With Quote
